Lowered Trucks: tech and info....
Old Nov 4, 2009 | 08:27 PM
  #491
oefootball_70's Avatar
oefootball_70
When I removed the springs on mine, I jacked up the front end under the cross member. And then removed one wheel, then used another jack under the control arm to compress the bitch. Unbolt, then slowly let off the pressure from the jack to remove pressure. Did the exact same thing opposite to re-compress it. Never used a coil compressor.
Old Nov 4, 2009 | 08:35 PM
  #492
RawRam2006's Avatar
RawRam2006
Hmm, well I might have to try that one. Thanks! I'm gonna try and tackle this one this weekend. At the very least hopefully I can have the rear flip kit done in one day. LOL. If I don't get to replacing the front coil springs this weekend I'll do em next weekend.
Why doesn't anyone (internet) have a good set of directions? I guess once I do this one I'm gonna have to make up a set and have it posted on here. LOL. Then the next guy who has a lowering kit to install won't have to go through the searching for directions, cause they'll be on here. LOL.
Old Nov 5, 2009 | 11:19 AM
  #493
tuned93's Avatar
tuned93
thats what i was gonna do, but i got into it and forgot to take pics... whoops!?
Old Nov 5, 2009 | 12:26 PM
  #494
straightblackram07's Avatar
straightblackram07
Let me know how it goes man, i'm putting mine on in a couple of weeks. I'm in the same boat you are, not so worried about the rear but the front is what i'm not entirely sure about. lol
Old Nov 5, 2009 | 04:40 PM
  #495
OklaHemi's Avatar
OklaHemi
i found these. i know one is the instructions for a lift kit but th3 removal is the same
http://www.ehow.com/how_4508904_repl...dodge-ram.html
http://www.trailmastersuspension.com...ions/DL222.pdf
i hope the help
Old Nov 5, 2009 | 04:46 PM
  #496
RawRam2006's Avatar
RawRam2006
They kinda helped. Thanks bro.
Old Nov 6, 2009 | 12:26 PM
  #497
tuned93's Avatar
tuned93
remember the PICS!!!
Old Nov 6, 2009 | 11:42 PM
  #498
RawRam2006's Avatar
RawRam2006
I'm gonna try and get pics and some decent directions on here. Maybe it would be beneficial if someone put it in a "sticky", lol. I do have one question though, if I were to do as was mentioned above and use a jack to compress the spring instead of a spring compressor, would I still need to disconnect the tie-rod ends? Cause I aint got no pickle fork. LOL. (maybe a flat headed screwdriver would work instead?).
Old Nov 7, 2009 | 03:15 AM
  #499
OklaHemi's Avatar
OklaHemi
here
http://hemitruckclub.com/Installs/Be...it/dropkit.htm
Old Nov 7, 2009 | 01:03 PM
  #500
BadHab1t's Avatar
BadHab1t
nice find mike thats a good write up....
