Lowered Trucks: tech and info....
Old Nov 18, 2009 | 10:52 AM
  #551
tuned93's Avatar
tuned93
did you get walked on my a SRT-8? and yeah, dremel & sawzall too!
Old Nov 18, 2009 | 11:15 AM
  #552
truckin151's Avatar
truckin151
Alright guys I think I am going to end up lowering the truck, not as low as some of you guys though.
Anyways this is the stance I want the truck to have after its all said and done, maybe an inch taller front and back though:
Its not slammed and it appears to still have a little rake to it which is what I like, and with it slightly taller that the one in the pic I should still have enough clearance to head up camping as well..... Now, what all do I need to give my truck that stance?
Old Nov 18, 2009 | 11:19 AM
  #553
SilverBullet08's Avatar
SilverBullet08
ot, but ive seen that truck in person its badass
Old Nov 18, 2009 | 11:24 AM
  #554
tuned93's Avatar
tuned93
you'd prolly need a 2/4 drop kit, and just not adjust the rear to the lower setting.
Old Nov 18, 2009 | 11:29 AM
  #555
truckin151's Avatar
truckin151
tuned you're going to have to explain that one to me a little more, what do you mean by not adjusting the rear to the lower setting?
Old Nov 18, 2009 | 11:32 AM
  #556
BadHab1t's Avatar
BadHab1t
you got two holes in the rear shackles just keep it in the high one... that will look great truckin and like ken said a 2/4 is what your looking for what i shoulda done....and still might.....no getting smoked by a srt 8 i said damn str8 straight.....i dont know if it was a srt 10 or not i wasnt in a good spot to run with him h had a whole open lane and just took off....if your talkin about the nightrunner....
Old Nov 18, 2009 | 11:36 AM
  #557
tuned93's Avatar
tuned93
usually when you get a rear flip kit it comes with shackles that are longer, but have 2 or 3 settings. so you can adjust from 2'' 4'' and 6'' of drop in the rear. (some have 2 settings, some have 3) anyways, when you install the shackles, just set it on the highest setting as to reduce the amount of drop you install. for exapmle: if you have 3 holes, top one being 2'' drop from factory, and the bottom one being 6'' drop... youd wanna install the leaf spring end on the top one to get a 2'' drop... from factory
Old Nov 18, 2009 | 11:37 AM
  #558
tuned93's Avatar
tuned93
oh true... damn str8. gay lol jk
Old Nov 18, 2009 | 11:40 AM
  #559
truckin151's Avatar
truckin151
I thought that if you did a rear flip kit that it automatically drops the rear x amount, so would it be 2" beyond that point or would it just be a 2" rear drop?
Old Nov 18, 2009 | 12:01 PM
  #560
BadHab1t's Avatar
BadHab1t
well a flip automaticly gives you a 4" drop period the lowest you can go with out a flip is the 2" drop shackles and o/l leaf delete unless you do something really ghetto and i know you wouldnt do that....but on the shckles in the flip kit you could go lower if you wish to providing it has slots for it.... but a 2/4 drop is nice and would give a grat stance mike oklahemi has a 3/5 on his....so you 'd be a lil higher.....the shackles may allow for you to be at a 2" drop with the axle flipped if the shackles are longer....had to reiterate...sorry
