Lowered Trucks: tech and info....
Old Aug 11, 2009 | 10:37 AM
  #81
OklaHemi's Avatar
OklaHemi
Originally Posted by tuned93
you'd have to notch your frame either way. more so if you bagged it...
i have heard of people doing a 4/6 on their rams w/o notching. i have also read a thread on D****talk.com where a guy did a homebrew drop for under 80.00.
Old Aug 11, 2009 | 11:32 AM
  #82
tuned93's Avatar
tuned93
Originally Posted by VP64
tuned93
what the heck are u going to do with that chrome bumper of yours. im sure u got asked this a bunch of times. srt 10 bumpers n wheels would do the trick
thats what im going for... but thats not the direction my bank account is headin
Old Aug 11, 2009 | 03:55 PM
  #83
mr gasser's Avatar
mr gasser
Originally Posted by OklaHemi
if you want to slam it you would want to airbag it. the kits are going for 1600.00 usd for everything you would need. then you could adjust the height to what ever you wanted whenever you wanted. if you just want a drop you would probably want a 4/6. but there is more work involved in going this low. you have to notch you frame for a good ride and remove wheel wells. there is more to be done to slam it.
ok thank you for the info, and sorry for my ignorance,but what do you mean 4/6 in the dropcase? can I obtain it changing only the spring in the front,with lowered one? how can I do for the rear? sorry again If you need info for aircooled vw don't esitate to contact me!!!!!!!!
Old Aug 11, 2009 | 05:18 PM
  #84
OklaHemi's Avatar
OklaHemi
to drop it 4 inches in the front would usually require changing your springs and spindels or control arms to maintain a good ride quality. you dont want to lower you truck 4 inches with just springs i dont even know if it is possible. on the rear for the 6 inch drop you would do a flip kit and drop shackles in most cases. there are kits available that have everything you would need. 4/6 usually going for 640.00+
http://cgi.ebay.com/ebaymotors/McGau...Q5fAccessories
you can do a 2/4 by changing the springs and doing a flip kit on the rear
Old Aug 11, 2009 | 05:21 PM
  #85
OklaHemi's Avatar
OklaHemi
your truck isn't a 4x4 is it?
Old Aug 11, 2009 | 06:44 PM
  #86
mr gasser's Avatar
mr gasser
thank you for all the info, my ram is a 2wd something change? it's your a 2 or 4 wd?
Old Aug 11, 2009 | 07:13 PM
  #87
OklaHemi's Avatar
OklaHemi
mine 2x4. you cant lower a 4x4 as easy. the suspension is different. i like your truck by the way. have you thought about putting some driving light behind the grill? im sure you dont see that in Italy every day
Old Aug 12, 2009 | 01:56 PM
  #88
tuned93's Avatar
tuned93
it basically all depends on what you wanna pay... the lower you go the more money you'll spend
Old Aug 12, 2009 | 06:44 PM
  #89
1LowRam's Avatar
1LowRam
Or do what i did. Buy it already lowered! I cheat!
Old Aug 13, 2009 | 01:05 AM
  #90
OklaHemi's Avatar
OklaHemi
mine was lowered when i got it as well. but i spent so much time researching a drop for my 08 and my 01 that i should be a salesman. i think i need to go a little lower, maybe later
