Lowered Trucks: tech and info....
Old Mar 4, 2010 | 10:25 AM
  #921
OklaHemi's Avatar
OklaHemi
it is a good price and will ride fine,
Old Mar 5, 2010 | 10:38 AM
  #922
Blk05HEMI's Avatar
Blk05HEMI
Hey guys i was wondering if any of yall have any instructions on removing the O/L Leaf to get a level drop. I just wanted to know because a friend and I are going to b doing this later on today/tomorrow.
ZW
Old Mar 5, 2010 | 02:52 PM
  #923
BadHab1t's Avatar
BadHab1t
one side at a time ...use 2 jacks one for the axle and 1 for the truck body...jack em up till no pressure unbolt wheel, four nuts on top of leaf plate, small nut on top of leaf plate...remove plate and u bolts, undo shock bottom bolt, lower axle, take bolt out of leaf pack, pry off o/l leaf....reassemble backwards the way you took it apart....real easy once you get in there and realize it....good luck
Old Mar 5, 2010 | 08:54 PM
  #924
M.A.'s Avatar
M.A.
Thanks Jusjay727,
What's o/l leaf ..... Is that something I can do myself? Will it change the ride? ... She does a lot of highway driving during the week. I'm new to all this ... Sorry for sounding stupid ... but I just don't know about these type of modifications ..... Still a newbie ...
Old Mar 5, 2010 | 09:10 PM
  #925
BadHab1t's Avatar
BadHab1t
overload leaf....its fine i did it myself...it changes the payload of the truck but if your like me my truck doesnt get used as a truck per say...only once in a while...im looking into a 2/4 drop later this summer/fall hopefully before slamfest...but i need a new job and with school its hard but hey gotta do what a mans gotta do....
Old Mar 6, 2010 | 02:01 AM
  #926
RedTruck-VA's Avatar
RedTruck-VA
It has been a long time since I pulled my O/L, but it seems the spring pack had a bolt that held it all together. I had to replace the bolt because it was too long and didn't have enough thread to pull the spring pack back together with the O/L spring removed. With the O/L spring removed I aligned the remaining springs using a philip screw driver and a "C" clamp. Pinched it tight and removed the screw driver and stuck my new bolt in place and tightened it up. Clean all the threads and anti-sieze them before putting it back together. I used an impact wrench which is not necessary but makes short work of everything. good luck. OBTW, my O/L springs appeared to have never been in contact with the other springs. I pull a VTX 1800 in a 12' enclosed motorcycle trailer. Not real heavy but not light either.
Old Mar 6, 2010 | 10:53 PM
  #927
06 Ram5.7's Avatar
06 Ram5.7
This may have been answered already, but I was looking at getting the McGaughy’s 2” drop shackles and had a question about shocks. With the drop shackles, do you need to get shorter shocks, or are stock size shocks ok?
Old Mar 6, 2010 | 11:41 PM
  #928
SilverBullet08's Avatar
SilverBullet08
you can clamp the overloads and you'll get the same amount of drop if you took it out. You can get leaf spring clamps at auto zone for about $10 or $15. when you clamp them clamp them at the front and it is also supposed to help with wheel hop. Doing it this way you can also take them off if you need to haul/tow something. i will prob end up doing this when i get my shackles
Old Mar 7, 2010 | 12:54 AM
  #929
RedTruck-VA
I have 60k on my truck and the shocks were shot. I replaced mine with shorter shocks and it really improved handling/ride. I put the rear axle on jacks and disconnected the bottom of the shock . Then pushed the OEM shock completely closed and measured it's lenght. Then I measured the distance between the axle and the frame (I don't have bumps). I found the shock to be too long. I went to Monroe's spec chart and found the shock that met my needs and ordered them at the local Auto Zone.
http://www.monroe.com/catalog/docume...engthSheet.pdf
good luck
Old Mar 7, 2010 | 02:25 AM
  #930
Blk05HEMI's Avatar
Blk05HEMI
Yes the clamps do work . When i had the clamps on mine i had front and back on both sides with the 2" shackle and my truck looked to b sitting lower in the back and damn shallow street dips it feels like your rear end is bouncing up and down. I ended up taking them off the truck looks much better with just the 2" shackles anyway.
The clamps and o/leaf would look better if i had smaller tires i have 275/60r20 my friend has a slightly smaller tire than me and his looks perfect (He has the 2" shackle and claps as well) I will porbably take the leaf out this spring break when i get my new tires.
ZW
