Lowered Trucks: tech and info....
Old 03-19-2010, 11:47 AM
astock's Avatar
astock
astock is offline
Any help would be appreciated..............I installed the McGuaghy's 2/4.5 spindle kit a few weeks ago, everything seemed to be fine. Yesterday I noticed a vibration in the rearend at 20-35 mph. I double checked everything yesterday after work and it's all tight. It seems like the rearend is moving around, if I hit the brakes hard you can hear the rearend move and also if I shift to reverse and gas the truck a little bit, you can hear a clunk in the back. Any ideas???? I am getting so aggravated that I almost want to put it back to stock.
  #982
Old 03-19-2010, 04:58 PM
MegaCabTodd's Avatar
MegaCabTodd
MegaCabTodd is offline
Originally Posted by RedTruck-VA
Isn't the Mega cabs based on a 2500 chasis? I would call McGaugheys and talk to them about fitment.
Yes it is the 2500 chassis. I will call them.
  #983
Old 03-19-2010, 07:25 PM
RedTruck-VA's Avatar
RedTruck-VA
RedTruck-VA is offline
As you have stated the housing is probably moving a bit. The vibration is either the result of the loose housing or the pinion angle has shifted. I would get it on up to where you can work on it and see if you find the problem. Look closely at the U bolts are the nuts bottomed out on the threads? This would make them feel tight but still not clamping the axle housing tightly enough to keep it from moving. This should be easy to spot and fix. Good luck...
  #984
Old 03-19-2010, 10:34 PM
BadHab1t's Avatar
BadHab1t
BadHab1t is offline
I agree with redtruck it should be easy to spot. Maybe just a bad u joint too.
  #985
Old 03-20-2010, 07:47 AM
astock's Avatar
astock
astock is offline
Has anybody needed to use shims with the flip kit? I should have time tomorrow to see if anything is loose and dive into it more.
  #986
Old 03-20-2010, 08:29 AM
RedTruck-VA
I used wedges on a chevy to align the pinion angle. The kit came wit them. I think you just have something that's worked loose. Good luck...
  #987
Old 03-21-2010, 01:24 PM
astock's Avatar
astock
astock is offline
You guys were right! I finally figured out what was wrong (knock on wood) The bottom plate was put on backwards. The two holes just weren't lined up right. Of course, had McGaughy's just sent me some instructions then I wouldn't have had to fuss with it and taken apart the rearend three times. Oh well, sometimes you have to learn the hard way. I will post some pics later, I got my new wheels on Friday and put them on today. By the way, no matter what McGaughy's says, the 17" wheels that I have DO NOT clear the lower balljoint bolt. Trust me!!
  #988
Old 03-21-2010, 03:56 PM
astock's Avatar
astock
astock is offline
Here she is.............I think I did fix the vibration. I was thinking of taking the front air deflector off, what do you think?
  #989
Old 03-21-2010, 04:01 PM
BadHab1t's Avatar
BadHab1t
BadHab1t is offline
damn man that looks sick...id paint the center of your bumper black and the cross hairs on your grill black and leave the flecter on and the b pillar between the windows on ya doors black ...it would be insanly sick....
  #990
Old 03-21-2010, 05:19 PM
MOusafLRT03's Avatar
MOusafLRT03
MOusafLRT03 is offline
Originally Posted by tuned93
lets see some pics of your truck...
ask, and yee shall receive...
and this pic of my "start" of taking off that pesky chrome...
Quick Reply: Lowered Trucks: tech and info....
