HorsePower & Torque Upgrades
Old Aug 8, 2009 | 05:29 AM
RamIt33's Avatar
RamIt33
Angry HorsePower & Torque Upgrades
Hey all anyone have advise for performance upgrades. I have a 2007 Dodge ram 1500 big horn with a 5.7.
Upgrades
77 series K/N intake
Super Chip Tuner
3'' True dual exhaust-
-Dual Flow master 40's
Air AId Throttle Body Spacer
22'' Boss Rims
my tuner is the only thing that i noticed a increase with power. The order i lined them up is the order i installed them. And my truck only runs 16.6 1/4 mile at 87 mph. ANy one have info or ideads please let me know.
RamIt33
Old Aug 8, 2009 | 08:41 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
CAI, gears, LSD, exhaust (headers??), tuner, ECT. The question is which do you wanna do first because eventually you will do them all if you are like most of us here. LOL
Old Aug 8, 2009 | 10:05 AM
HammerZ71's Avatar
HammerZ71
Take the throttle body spacer out (actually losses power for you on a modern throttle body), ditch the flowmaster 40s (great sound, but the chambered design flow much worse than even stock). Ditch the 22" Wheels for something with less weight.
Even though it doesn't add any HP or Torque, you are not going to see much in the way of 1/4 time gains until you re-gear that thing with 4.56 gears. A better aftermarket torque converter would be imperative too. All the performance mods you dump money into are just losing 25% or more before they reach the rear wheels because of the stock torque converter.
Fix the gears and torque converter first, then you can concentrate on mods that make more power like headers, cam, custom tune, heads, etc...
Old Aug 8, 2009 | 10:29 AM
BEAR's Avatar
BEAR
Another piece of wisdom from the wise Hammerson! AAHH little Grasshoppers heed the wisdom!
Old Aug 8, 2009 | 11:30 AM
Off_Road_Teacher's Avatar
Off_Road_Teacher
Upgrades
Super Chip Tuner
22'' Boss Rims
That time seems slow for that list mods. Personally, I think that if you are looking to increased performance you should ditch those big rims. The added rotating mass is not helping your times.
Old Aug 8, 2009 | 11:45 AM
dirtydog's Avatar
dirtydog
Moderate User
Not really. if he has lower profile tires, those aren't heavier than 20's with 33" rubber because the loss of rubber offsets the rim weight. i would guess 5lbs difference at most between stock 20's and 22" SRT size.
You say True 3" duals....You got Long tube headers? Do you still have the factory Y-pipe? Then it's not True Dual. i dunno why everyone thinks that is true dual?
Anways, that 3" doesn't help much because the factry y-pipe is only 2.5" AND it has a totally Smashed merge pipe which hinders flow.
Get yourself some gears, Headers, Cam. Those 3 will drop your times significantly.
Old Aug 8, 2009 | 11:50 AM
mdram43's Avatar
mdram43
well ya did buy a truck, not a vette or viper. that does seem a little slow, and like everyone else said, if your worried about quarter mile times 22's are not the way to go
Old Aug 8, 2009 | 01:07 PM
dunerider650's Avatar
dunerider650
get rid of the big rims...and if you are running true duals SPECIALY 3" your loosing power ditch all that.
Old Aug 8, 2009 | 01:12 PM
lxman1's Avatar
lxman1
Site Moderator
Put 2.5" dual exhaust on it and it will be better than dual 3". Too much of a good think can kill you
Old Aug 8, 2009 | 02:16 PM
truckin151's Avatar
truckin151
First off you have a heavy *** truck, not a carbon fiber sports car so you need to tune it for more low end than top end to get the truck off the line and out of the hole faster. Gears for sure will help change that torque curve a bit to the low end 4.10-4.56, then an aftermarket converter to get rid of a hell of a lot of loss through the drive train and help get the power down to your wheels a lot better over stock. After that some headers, cam, heads, a proper dyno tune and a more free flowing exhaust to make the true duals work to your benefit.
