Clear fluid leaking!!!!
Old Aug 10, 2009 | 12:26 AM
madsn11's Avatar
madsn11
Angry Clear fluid leaking!!!!
Well I pulled into the driveway today and was working in the garage and noticed something leaking from the passenger side of my truck! I go in to pop the hood and noticed allitle bit of fluid on the driver side floor mat also. There is a descent size puddle on the passenger side of the truck and looks like its coming from right under the passenger floorboard. It is clear in color and cant figure out where the hell its leaking from any suggestions????? Thanks.
Old Aug 10, 2009 | 12:31 AM
Blown287's Avatar
Blown287
Its not condensation from the A/C draining down is it?
Old Aug 10, 2009 | 01:07 AM
hemiguy0302's Avatar
hemiguy0302
give it a smell posibly a taste if your feeling confident it isnt harmful
but Im willing to bet this is just some condensation not draining
right from the AC components under the dash. Try running the truck without
AC on if now juice appears then your culprit is AC
Got_Hemi44's Avatar
Got_Hemi44
If it's clear and oily, it's probably your brake fluid.
If it's clear and not oily, it's a/c condensation or wind shield washer fluid. (a/c won't have a smell)
Old Aug 10, 2009 | 01:26 AM
hemiguy0302
oh **** yeah brake flujid does kinda make more sense on the friver side
but wouldnt he also be feeling spongy pedal cause if fluid gets out air gets
in and yeah no brakes but regrdless dont taste fluid it could be really bad
fo you
Old Aug 10, 2009 | 01:28 AM
Blown287's Avatar
Blown287
Yeah, he's saying passenger side though
Old Aug 10, 2009 | 01:41 AM
hemiguy0302
okay so ac then
Old Aug 10, 2009 | 01:49 AM
BigHorned's Avatar
BigHorned
just to chime in...yep a/c condensation. try to find the drain tube that should be in the engine compartment and either have a tube or a black flat nipple that is soft hanging below the cab roll in the front. haha soft nipple...check by squeezing the tube or nipple and see if any water comes out.
Old Aug 10, 2009 | 06:57 AM
RubberFrog's Avatar
RubberFrog
sounds hot!
Old Aug 10, 2009 | 07:52 AM
abarmby's Avatar
abarmby
Can you say that on here????
"check by squeezing the tube or nipple" LOL LOL LOL
His problem does sound like the AC though.
Al.
