275-65-20
Old Aug 17, 2009 | 08:47 AM
Mopar21277's Avatar
Mopar21277
Default 275-65-20
Hey guys, I'm leaning towards a set of Goodyear ATS in 275/65/20 typical of the Ford Superdutys. Right now I'm on a set of worn out Pirelli 275/55/20, which are way too small, as they don't look right.
I've got the Power Wagon flares and 4.56 gears, so if the 65's will fit without rubbing, it should be a great setup. Is anyone running these big of tires, ~34" without special lift kits? I'm lifted a few rounds on the torsion bars now. Thanks a lot!
Old Aug 17, 2009 | 09:04 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Stock 20s were 60 werent they?
Old Aug 17, 2009 | 09:12 AM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
with the torsion bar cranked a little bit those will slide right in. go for it. shouldn't have any rub at all.
yes, stock is 275 60 20
Old Aug 17, 2009 | 09:29 AM
HammerZ71's Avatar
HammerZ71
Not a big fan of Goodyear tires, every set I've owned have had issues from cupping to belt separations and many guys I've known and on the forums have complained of the same issues...
Old Aug 17, 2009 | 09:49 AM
Hemi1500_600RR's Avatar
Hemi1500_600RR
I am running 275/65/20 on a 1500 Hemi without any issues at all. No rub, but I do have a cupping issue a little bit and I align and rotated every 8000 and 5000 repectively.
Old Aug 17, 2009 | 07:34 PM
lxman1's Avatar
lxman1
Site Moderator
Common problem with 20's according to my dealer. The crappy front shocks don't help much. Mine has cupped all 4 tires now since they have been rotated a couple of times. Going back to the dealer soon.
Old Aug 17, 2009 | 09:15 PM
dave-o's Avatar
dave-o
305 55 20 would look good, but they are $100 more a tire compared to 275 60 20 if you want a m/t, 33 12.5 20 would look good as well, with the 4.56 gears, i would go with 35 12.5 20
Old Aug 17, 2009 | 09:24 PM
Bluesmanjesse's Avatar
Bluesmanjesse
You may find this useful in your quest,I know it's been posted here more than once before. http://www.redrock4x4.com/tech/tire_calc.php .
Old Aug 18, 2009 | 08:24 AM
Mopar21277's Avatar
Mopar21277
Thanks a lot guys, I'm still struggling here a bit with the selection. I want the bigger tire look, but I don't want to spend a ton of $$$ on them, as I'm probably getting a new ride next spring/summer. I've never been a big fan of Goodyears, but the options seem a little limited. I can get ATS 65 series to my door for around $170 each, which is tough to beat. The Nittos and Bridgestones are around $250+ each which is pretty significant.
The gears should be great with the bigger tires; even with the little worn out 32's, she runs about 2250 rpm at 70 mph. It still blows my mind having 3.55's with 33" tires from the factory...
Old Aug 18, 2009 | 10:46 AM
dave-o's Avatar
dave-o
if money is the issue, check out the cooper zeon ltz from treadepot.com or discount tires, they are $143 a tire
