Help with 5.7 timing chain replacement
Old Aug 23, 2009 | 11:21 PM
2k1AmberR/T's Avatar
2k1AmberR/T
Default Help with 5.7 timing chain replacement
Hey guys, a buddy of mine would like to replace his timing chain and water pump and hoses sometime soon, he's a bit over 100k miles. I'm just looking for any part numbers or information any of you might have for a timing chain and gaskets necessary to do this.
Old Aug 23, 2009 | 11:39 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
www.autozone.com has everything you need.
Old Aug 24, 2009 | 12:38 AM
draco8494's Avatar
draco8494
over 100k and replacing the timing chain?? what gives? also take lots of pics
Old Aug 24, 2009 | 01:06 AM
2k1AmberR/T
They have double roller timing chains?
Old Aug 24, 2009 | 07:38 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
That have OEM replacements and being most guys never change thier chains and go well up into some very high mileage, I think they are just fine to keep.
I did a double roller on my custom built SBO 350 for my 442. But you have to understand it has TRW flat top fordged pistons, 100 shot of Nos, shot peened beams, halo girdle on the bottom, E-brock RPM cam/carb/intake and a Comp Cams adjustable VT, By point is it (IMO) needed a double roller because of the stress I was going to put on it and high RPMs. If you arent building an all-out engine then I think the OEM chain is fine for you. I mean, the last one got you past 100k didnt it? Besides, not only would you need the chain but the sprockets to go with it (upper and lower).
Old Feb 17, 2012 | 05:15 PM
zteeters's Avatar
zteeters
My timing chain broke on my 07 ram at 53000 miles, What a mess, and chrysler says there is no problem with there parts...hmmmm
Check my other thread I posted a pic.
Old Feb 17, 2012 | 06:06 PM
MikeHTally's Avatar
MikeHTally
Timing chains usually last a long time, 200K or so. Certainly not a maintenance item. Is your buddy confusing timing chains and timing belts?
Old Feb 17, 2012 | 08:40 PM
NV290's Avatar
NV290
That is what i was thinking. 100k miles is the norm for most car companies service interval for timing belts. But timing chains? I don't recall EVER seeing a car company including timing chain replacement into a service schedule. Doing a water pump change seems a bit excessive too. But a to do a timing chain at 100k miles (in my opinion) is nothing more then a waste of time and money. I work with a guy with an 04' Ram who is nearing 180,000 miles and the whole engine is original with the exception of the fan belt.
Old Feb 17, 2012 | 08:46 PM
NV290's Avatar
NV290
What happened to you was simply bad luck with a part. Like throwing a rod under normal driving. If the timing chains were truly a flawed part, you would be hearing a lot more about people with timing chan issues. And i for one have not heard of many.
Old Feb 18, 2012 | 04:34 AM
abarmby's Avatar
abarmby
I have read several posts of the timing chain tensioner being worn and in need of being replaced on engine rebuilds.
Al.
