Nitrous setup on a 2005 4.7L
Old Aug 26, 2009 | 04:54 PM
gmb4fords's Avatar
gmb4fords
way way waaaaaayyyyy off topic but where do you get the crazy smileyz?
Old Aug 26, 2009 | 05:36 PM
miller456's Avatar
miller456
when you click new reply theres smilies on the right hand side of where your typing dont you see them? you can also click the "more" link to choose different ones.
dirtydog's Avatar
dirtydog
Moderate User
Originally Posted by miller456
Interesting response, but to debate a point, dry shots are not a thing of the past and there is no reason to do a wet shot if he doesnt desire. There is no puddling of fuel with a dry shot b/c you upgrade the injectors to make up the fuel difference. A 75 shot should be just fine with stock injectors, no puddling=no backfire. Also he does not NEED a bottle heater. He COULD get a NANO system which is instant pressure and keeps it consistant throughout the entire run, unlike a bottle heater which takes time to build pressure and loses it during a pass.
Excellent info from a Newbie! I am unfamiliar with the Nano system so I cannot comment on that.
I never liked dry shots because you must get the injectors to suit your needs where as a wet kit does all the dirty work for you. Dry kit for a custom tune is the way to go, BUT, most guys aren't looking to spend $2k+ for a N20 set-up. In fact most guys do it for budget and have no idea how expensive the proper set-up can be. Injectors alone can run upwards of $600.
Old Aug 26, 2009 | 05:44 PM
miller456's Avatar
miller456
Haha thanks for the noob call out! Im pretty familiar with nitrous setups from putting them on my camaro but not a guru. Id say a 75 shot should be ok with stock injectors but anything larger and you should move up. I spent around $1300 for my kit and thats the minimum for safety equipment. Goodluck to the OP on a kit if you do get one I agree NX will do you right.
Old Aug 26, 2009 | 06:10 PM
gmb4fords's Avatar
gmb4fords
well i dont see the smilies but yea NX is usually the better way to go. thats what all my friends use on their mustangs and camaros. going by what they say and their experiences
Old Aug 26, 2009 | 06:22 PM
truckin151's Avatar
truckin151
gmb4fords - You actually have to click the "New Reply" button or the "Go Advanced" button. They dont show up under the basic Quick Reply
Old Aug 26, 2009 | 07:00 PM
Horseapples's Avatar
Horseapples
Wow, interesting stuff. But still, the head gasket issue remains. I am using an NX system on my truck, 175 hp wet shot with a Nitrous Outlet injection plate.
Old Aug 26, 2009 | 07:30 PM
lxman1's Avatar
lxman1
Site Moderator
Most stock sized injectors will not add enough fuel to safely run a dry kit. Did the head gasket thing on my Mustang with a dry kit, after Ford replaced the gaskets under warranty , I went with a 100hp wet kit and never had any more problems.
As mentioned, the problem is the weak head gasket situation of the 4.7L. Also, without a computer interface, you will not be able to retard the timing for safe use of the n0s.
Old Aug 26, 2009 | 10:15 PM
AIR RAM's Avatar
AIR RAM
Actually the head gaskets are not a common issue with the 4.7L... Im surprised to see somone brought them up as a concern. Sure they go out but its not so common and its normaly due to overheating reated issues rather then HP/BOOST.
With that said, the REAL issues the 4.7L has are the "CRAP" factory pistons and Rods.
The top ring is only 1/8" below the piston top. This means there very little meterial protecting the thin top ring from the extream temps associated with boost and LEAN BOOST. The 4.7L can take a 100+ shot easily... Its going lean at WOT that will leave you with broken parts.
What happens when the AFR goes lean, your piston tops get hot, that heat is transfered to the top ring, the top ring expands and seizes against the inner bore of the cylinder, the piston tops rip off and you normally get a HUGE exposion out the intake which in most cases causes the plastic intake to come appart in 100 pieces. Then the first thing people say is... " Oh the intake exploded because you had fuel pooling in the intake thats what happend"
Bottom line, the pistons are NOT forgiving. They will NOT take even a mild case of detonation well. So if you plan to run Nitrous make sure you get yourself a good WIDE BAND DATA LOGER/GUAGE and NEVER NEVER run it lean.
SPEED SAFE, AIR RAM
Old Aug 27, 2009 | 06:46 AM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
Sure the pressure of the gas is greatly increased but Nitorus oxide is 50% more dense than air at the same pressure. One cubic foot of N20 contains 2.3x's as much oxygen as 1 cu/ft of air.
ADDING EXTRA FUEL is what causes higher dynamic cylinder pressures. NOT the N20 itself!!!
Lol, dog that's like saying 'its not the beer that'll get you drunk, it's the alcohol', but who the f drinks no alcohol beer?
