Fiberglassing
Old Aug 26, 2009 | 06:14 PM
gmb4fords's Avatar
gmb4fords
Default Fiberglassing
I have decided that i would like to try this out. Have no ides what good i am going to use it for... maybe putting in a double din... but i just wanna learn how to do it. so does anyone "dabble" in fiberglass or know where i can get like a started kit from? i googled it and found a bunch that are for building boats and the kits are like 200 and up... im thinkin more along 50 to 100 lol. thanks in advance
Old Aug 26, 2009 | 08:10 PM
RubberFrog's Avatar
RubberFrog
You don't need a kit. Get a roll of mat, a can of resin, a tube of hardener and start playing. Try to make a square box. You'll be surprised how difficult it is at first, but you can quickly become proficient. And it's ok to skim a little bondo when you're done.
Old Aug 26, 2009 | 08:46 PM
hemipower05's Avatar
hemipower05
where can u get that stuff?
Old Aug 26, 2009 | 08:48 PM
RubberFrog's Avatar
RubberFrog
advanced auto, vato zone, home depot
Old Aug 26, 2009 | 08:51 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
And Lowes or Home Depot.
Old Aug 27, 2009 | 09:26 AM
gmb4fords's Avatar
gmb4fords
this mat material... what section of lowes and is it just called fiberglass mat or what? thanks again
Old Aug 27, 2009 | 09:31 AM
nim81's Avatar
nim81
its fiberglass mesh i think
Old Aug 27, 2009 | 11:45 AM
kx250frider617's Avatar
kx250frider617
I fiberglassed my whole enclosure if you want to check out my gallery. Basically the mat is a bunch of strands of fiberglass that is all bunched up, its used to make big things like a whole enclosure since after adding layers it builds up quickly and gets think. The mesh is more of a thin sheet of fiberglass like what they use on surfboards and for presice things. For the dash I would use the mesh sheet. The mat is harder to form to sharp edges. What you need is your fiberglass mat or mesh, a gallon of resin. catalyst (you only need a lil). Also dont forget the GREEN painters tape. This car wax-forgot the name, ACETONE, and a few cheap paintbrushes along with small buckets and stir sticks. You have to apply the painters tap to the surface you are fiberglassing being sure to start from the bottom up (the resin will easily flow through the creases between the tape) Then apply the wax on top of the tape. This makes it easy to pop out the mold when everything dries. Mix your resin and work fast. You fiberglass on top of the wax.
Old Aug 27, 2009 | 03:22 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
The materials would be in the paint dept.
Old Aug 27, 2009 | 04:53 PM
gmb4fords's Avatar
gmb4fords
sweeeeeeeeeeeet! thanks guys might go do some shopping tomorrow!
