285/65/20 bfg ???
Old Sep 10, 2009 | 02:37 PM
greenshovel's Avatar
greenshovel
Question 285/65/20 bfg ???
I did a search and couldn't find a clear answer. I need a little advise anyone running 285/65/20/DIA-34.7/WIDTH-11.5 BF Goodrich's on the stock 20 inch rim with a level kit? The truck is an 08 4x4, If so any issues with rubbing? I do know that 06-08 have the same suspension anything prior will be different for clearance issues (spring cup) Thanks (o:
I am also looking at the LT275/65/20/DIA-34.09/WIDTH-10.98 Nitto Terra Grappler, this should fit as the width is the same as the stock goodforayear tire on there right now
Thanks for any help...
Steve
Old Sep 10, 2009 | 03:02 PM
dirtydog's Avatar
dirtydog
Moderate User
No issue's as long as you've got a leveling kit. Stock width is 10.8" and 33" tall. The width on those isn't as big as a deal as the overall height is. 35x12.5's may rub slightly at full lock, but you should have no issue's at all with any of the tires listed.
Old Sep 10, 2009 | 04:09 PM
greenshovel
Thanks I really want to go with the BFG's I will also be putting in a 3" PA body lift proir to the tires sometime in Nov? Then the new tires next year, I still have a bit of tread left right now that will last into next year....
Old Sep 10, 2009 | 06:46 PM
lxman1's Avatar
lxman1
Site Moderator
I love BGF tires. That's all I buy anymore.
Old Sep 10, 2009 | 09:46 PM
AsphaltCowboy's Avatar
AsphaltCowboy
i was thinkin about gettin some Trxus MT's in a 33x12.50R20. will a set of 35's work on the stock susp on an 08 4x4?
Old Sep 10, 2009 | 10:33 PM
greenshovel
12.5 will need a wheel spacer....
Old Sep 10, 2009 | 10:54 PM
luv24x4's Avatar
luv24x4
further to his question, does anyone know if the 285/65-20 will fit on the 08 4X4 with no leveling kit?
Old Sep 10, 2009 | 11:03 PM
dirtydog's Avatar
dirtydog
Moderate User
This has already been answered.
