2006 1500 4x4 5.7l towing
Old Sep 14, 2009 | 03:41 PM
tattoobiker13's Avatar
tattoobiker13
Default 2006 1500 4x4 5.7l towing
hi there just got a 2006 ram 1500 4x4 sport with the mds, i live in vancouver b.c canada and i am driving down to las vegas wich is 2200km each way and my question is that i will be towing a enclosed cargo trailer with a harley in the back, the whole thing is only going to way around 3000lbs, the truck is totaly stock i am just wondering if there are any tips or precautions i should take on a long haul like this even though it is not a lot of weight, like is it going to be hard on the truck towing for hours on end like that, is the trans cooler sufficient? should i take breaks or run at certain speeds? use a certain octane i currently run 89. anyway any tips or help would be appreciated.
Old Sep 14, 2009 | 04:19 PM
rickmeseke's Avatar
rickmeseke
you should be perfectly fine as is. though i dont have a ram, but a dakota 4.7, i pulled 3200 900 miles each way without stopping, except for food and bathroom twice, and WITHOUT TRAILER BRAKES, it handled exceptionally well. you have no worries!
Old Sep 14, 2009 | 04:50 PM
WWJD's Avatar
WWJD
Nothing except for regular stuff you do when towing. Make sure all equipment is hooked right lights working. Trailer bearing's greased, tires properly inflated and so on.
3000 lbs should be an effortless load for your truck. I have an '02 4.7 that has pulled that with no problem.
Old Sep 14, 2009 | 06:39 PM
tattoobiker13
thanks thats what i thought
Old Sep 14, 2009 | 06:42 PM
tattoobiker13
Hey also what is this e fan thing people are talking about on here?
thank you.
Old Sep 14, 2009 | 07:52 PM
OlDirtyJohn's Avatar
OlDirtyJohn
thank you.
they are talking about an electric fan. it replaces the stock clutch fan which runs off the engine and takes up a few hp.
Old Sep 14, 2009 | 08:32 PM
dirtydog's Avatar
dirtydog
Moderate User
You won't even notice that trailer behind you much. You'll be fine.
Old Sep 15, 2009 | 01:07 AM
tattoobiker13
ok thanks but does it really do anything noticeable? how is it to swap out?
