02 ram 4.7 help please
When I read this thread it was like deja vu, my 02 Ram (4.7l) is doing exactly the same thing. Earlier I cleaned the throttle body and it did not seem to help much. The problem seemed to go away after I replaced the battery (!!) but has now returned. I will be checking the wires to the coil packs asap to see if that has any bearing on the issue. I live in the UK so getting parts is a fairly big deal. What is the correct term for the coil packs that sit on the spark plugs as I think I need to replace these and am having trouble sourcing the part. Am really glad I joined the forum now.
on
Picky a$$ engines, my Hemi HATES platinum plugs and my 4.7 HO can only use them. So much for buying plugs in bulk!!!
4.7 plugs
Thanks a lot guys, that might have saved me wasting money on coil packs. Cheers. Whilst I am on, I found today that my exhaust system needs replacing, the system fitted is a full twin sports system (ie there are two seperate tail pipes). The sound is (was)awesome so I would like to fit a similar system, have you any recommendations, in stainless os course, cheers
