beach a problem?
Old Sep 20, 2009 | 07:31 PM
mcgoo89's Avatar
mcgoo89
Default beach a problem?
I've got an 02 ram 4.7 and I'm wondering if there is any issue with this truck on the beach? I was on the for prob around an hour of driving, not going over 2500 rpms and I watcged my temp start to rise to 3/4 so I had to get off and everything was fine again.. It went right back down to normal. Wat was that about? And any tires you guys suggest for the beach? Sorry for length and thank you everyone
Old Sep 20, 2009 | 07:34 PM
BadHab1t's Avatar
BadHab1t
ive never had a problem with mine on the beach at all i have stock 20" wheels and new street tires soi come close to getting stuck once but just gassed it out....
Old Sep 20, 2009 | 07:36 PM
nim81's Avatar
nim81
nitto dune grapplers are said to be the best tires for sand..
lxman1's Avatar
lxman1
Site Moderator
The most common problem with the early 3rd gen Rams is the radiators get partially clogged. I would check for cool spots when hot. This is a good way to pop a head gasket on a 4.7L.
Old Sep 20, 2009 | 08:15 PM
mcgoo89's Avatar
mcgoo89
I replaced the radiator like 10000 miles ago because it was clogged. It was just weird how it went right back to normal when I got off the beach
Old Sep 20, 2009 | 08:18 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Mine did the same thing driving in 4high I was up around 240. I don't know why but it got hot.
Old Sep 20, 2009 | 08:19 PM
Mega-Hemi's Avatar
Mega-Hemi
Driving through the sand probably just puts it under a constant load.
Old Sep 20, 2009 | 08:22 PM
dodge15004x45.9
I'm sure it does I was doing 20-40mph. Note the 40 was when there was no one around. When there was kids around I was lower than 20.
Old Sep 20, 2009 | 08:23 PM
mcgoo89's Avatar
mcgoo89
Should I go in 4L instead?
Old Sep 20, 2009 | 08:26 PM
dodge15004x45.9
If its soft sand yes. But that will not fix the issue at hand.
