lighted squares around PRND321
Old Sep 30, 2009 | 10:51 AM
gdawg's Avatar
gdawg
Default lighted squares around PRND321
not sure how well that gives you guys a picture of my question or not, but sometimes, not always, i get lighted squares or outlines around each individual PRND321.... can anyone tell me what this means?
Old Sep 30, 2009 | 12:06 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
It means that you are in that 'gear'...i.e. if you are in reverse, the R should have a square around it.
Old Sep 30, 2009 | 12:22 PM
speed_man13's Avatar
speed_man13
umm....r u serious? no offense but, really?
Old Sep 30, 2009 | 01:58 PM
gdawg's Avatar
gdawg
i guess i didn't explain myself enough......
they are sometimes ALL lit up.....squares around EACH letter and number ALL at the SAME time....
Old Sep 30, 2009 | 02:28 PM
Hoss356's Avatar
Hoss356
Mine did that when I was uploading tunes from the programmer but never by itself. Sounds like a PCM issue, the truck still runs fine though right? BTW what is a K7 1500? K is usually an abbreviation for 1,000 but it would still need a number as in 2K=2,000. Unless K=200 in some weird way.
Old Sep 30, 2009 | 03:02 PM
gdawg's Avatar
gdawg
yes, truck still runs fine.... just something odd i have seen a few times.....usually when it's in park, pulling it into drive usually makes them go out..
i say k7 as in 2007..... a motorcycle board i am a member of always uses it for model year... as in K8 suzuki 650 i figured everyone did it......
Old Sep 30, 2009 | 03:18 PM
dunerider650's Avatar
dunerider650
Yep....mine only does that when im screwing around with the pcm with my tuner....sounds like a pcm issue....
Old Sep 30, 2009 | 03:23 PM
gdawg's Avatar
gdawg
is that covered under warranty? since it doesn't do it all the time, would you guys just drive it? or get it to the stealers asap ?
Old Sep 30, 2009 | 03:42 PM
xfeejayx's Avatar
xfeejayx
I would just drive it. if it only does it in park, it might just be a startup thing. Are you noticing it right when you turn the key? the stealership is going to charge you a diagnostic fee, and once they got it they'll try their damndest to keep it.
Old Sep 30, 2009 | 03:47 PM
gdawg's Avatar
gdawg
no, i can drive it short distance, put it in park, and they all light up..... but like i said, it's not always...and not always common.... guess i'll let it go for now......
