06 dodge hemi computer
Old Oct 4, 2009 | 04:17 PM
torquefreak's Avatar
torquefreak
Default 06 dodge hemi computer
i was wondering if i can swap in a 2007 1500 hemi ecm into my 06 1500 hemi?
are they interchangeable thru 2006-2008?
Old Oct 4, 2009 | 04:28 PM
dirtydog's Avatar
dirtydog
Moderate User
pretty sure you would need a dealer to re-program since the ecu and speedometer cluster won't match up. They need to comunicate to each other before you can start the vehicle.
Old Oct 4, 2009 | 05:39 PM
torquefreak
they arnt the same cluster?
Old Oct 4, 2009 | 05:45 PM
dirtydog's Avatar
dirtydog
Moderate User
They are, but the operate on a diff. frequency.
I'll try to explain it simply.
Your key has a chip inside of it. When you insert it into the ignition it sends a specific rf frequency to the cluster. Then the cluster sends that frequency to the ecu, thus is why i said a dealer would need to "sync" everything together. i don't think your ecu would recognize your cluster or your programmed key as it's all about theft deterrent.
Old Oct 4, 2009 | 06:08 PM
torquefreak
so i could get the o7 ecu install it, and if it didntwork i could get dodge to reflash the ecu? would it still be 07 prgramming?
Old Oct 4, 2009 | 06:52 PM
dirtydog's Avatar
dirtydog
Moderate User
Why are you looking to change first of all?
Old Oct 4, 2009 | 08:21 PM
torquefreak
ive worked on alot of hemi rams, and rebuilt alot of the motors, and i cant find the reason why a edge evolution will not program the 06 or 08, except for possibly the calibration in the ecm probably.
Old Oct 4, 2009 | 08:49 PM
kicker417's Avatar
kicker417
then just get a different programer
Old Oct 5, 2009 | 12:38 AM
lxman1's Avatar
lxman1
Site Moderator
Get a better programmer!! Get a Predator and be done with it!!!
Old Oct 5, 2009 | 01:01 AM
torquefreak
i cant return this programmer and cannot find a buyer for it.
