Need help deciding what gears to get???
Old Oct 9, 2009 | 11:46 PM
shadow11's Avatar
shadow11
Default Need help deciding what gears to get???
So either tomorrow or Monday I am going to get either 4.11 or 4.56 gears for my truck (03 1500 4.7 2wd with 20"s and 3.55 gears right now). So my question is which gears should I get? I don't want to regret not getting the 4.56 if I get the 4.11 however I do drive on the freeway some and I don't want my rpms to be at 3k going 75mph. How much higher will the rpms go with 4.56 at 70mph cause right now they are at about 1900rpm at 70mph. I do tow and I know they will help alot and they will also help with around town driving as the 3.55 are really bad for towing. Also I am getting them installed at 4 wheel parts and they quoted me $650 for the gears and install. I think this is a good price?? Also I read some where that if I get the 4.11 they will really be more like 3.7? since I have the 20" wheels? So then I would really need to get the 4.56s. Thanks for the help in advance!!!
Old Oct 10, 2009 | 02:03 AM
abarmby's Avatar
abarmby
I believe I read on amother forum, that a guy with a 4.7 running 20's was turning 2200rpm at about 70.
There is a calculator somewhere that you can use.
Someone will chime in.
I believe that 4:56's with 20's is the way to go.
Hope this helps?
Al
Old Oct 10, 2009 | 03:36 AM
Pyro's Avatar
Pyro
I Beat Tetris
Does not matter what your rim size is, just the overall tire diameter. I'm running 33" tires, 4.56 gears, and turning 2400rpm at 70mph.
Old Oct 10, 2009 | 06:19 AM
abarmby's Avatar
abarmby
[QUOTE=Pyro;1832030]Does not matter what your rim size is, just the overall tire diameter.
Correct.
Al.
Old Oct 10, 2009 | 08:11 AM
Off_Road_Teacher's Avatar
Off_Road_Teacher
Get the 4.56 gears, they are the better choice out of the two you listed.
Old Oct 10, 2009 | 09:45 AM
TRXHemi's Avatar
TRXHemi
Remember, the 17s and the 20s have close to the same rolling diameter...the 17" tire just has a bigger sidewall.
I have the 4.10s with mine. At 70, I am running about 2000rpms.
Old Oct 10, 2009 | 10:45 AM
ramhunter9's Avatar
ramhunter9
i vote 4:56
Old Oct 10, 2009 | 11:30 AM
shadow11's Avatar
shadow11
Ok so I call them back this morning and they say it will be $859 instead of $625. So I am like you told me yesterday it would be $625 for everything to do the install so why is it so much more? Then he says they didn't quote me for the master install kit and bearings ect... So I don't know now if I am going to get the gears or not. Does $859 still sound like a good price?? Seems a little high to me?
Old Oct 10, 2009 | 11:35 AM
Off_Road_Teacher
Is the $859 including the new gears or just the cost of the install?
Old Oct 10, 2009 | 11:50 AM
ramhunter9's Avatar
ramhunter9
well a 4x4 in my area with master kit and install on 2 pumpkins will run you 1200
