Bad brake smell and burnig
Old Oct 11, 2009 | 12:25 AM
Waldosram's Avatar
Waldosram
Default Bad brake smell and burnig
I ran over a screw about 2 days ago and when i fixed it and put it back on, my front drivers side brake smells like it is burning and idk why, it only started after i put the tire back on the truck, dose anybody have any ideas or any suggestions????? PLEASE HELP
Old Oct 11, 2009 | 01:10 AM
lxman1's Avatar
lxman1
Site Moderator
Welcome to the forum.
I can't see how putting a wheel back on would cause brake problems.
Sounds like the caliper might be sticking or the rubber brake line has internally collapsed causing pressure to stay on the caliper and is making the pads drag.
Jack it up and see if the wheel turns free.
Old Oct 11, 2009 | 01:18 AM
cheapbeater's Avatar
cheapbeater
along with what lex said, maybe you bumped the metal part of the line with the tire and pinched it or something??
Old Oct 11, 2009 | 05:30 AM
abarmby's Avatar
abarmby
Yeah+1 with what the guys said.
Sounds like the caliper is sticking causing your brake to bind for some reason.
Is the truck pulling to one side under braking?
Go for a drive and when you smell this acrid smell, brake steadily and let go of the steering wheel a "little". Watch for pulling to one side.
If it does, the calipers sticking.
Al.
Old Oct 11, 2009 | 08:44 AM
Waldosram's Avatar
Waldosram
no, it dosent pull to one side or the other and the front wheels still spin freely, they <<<<Firestone>>>>>> used a impact to tighten it, could it have been put on too tight?
Old Oct 11, 2009 | 11:41 AM
lxman1's Avatar
lxman1
Site Moderator
Could possibly warp a rotor if it was not flush when they buzzed the lugs on.
Old Oct 11, 2009 | 12:44 PM
Murrayman23's Avatar
Murrayman23
geez lxman...great minds think alike i guess....i'm gonna go with lxman again...the rotor might be warped causing the pads to come in contact with the rotor as it goes around very fast. does it usually only happen at high speeds? or when your braking?
Old Oct 11, 2009 | 03:16 PM
abarmby's Avatar
abarmby
See, that's why you should always "torque yer nuts" lol instead of using an impact.
But, he said that the wheels span up nice and free.
I would have thought he'd have heard a warped rotor rubbing as the wheel revolved??
Al.
Old Oct 12, 2009 | 10:28 AM
Waldosram's Avatar
Waldosram
no, it only shakes when i am beteween 50-60 mph. It runs fine till i get to about 55 and it shakes badly and when i get above 60 it goes away. Is it possable that the tire is on kinda bobled, not flush when it was put on, and is wobbling when i reach these speds? and i dont hear anything going down the road while its happening.
