Tow/Haul Mode, do I have it?
Old Oct 19, 2009 | 09:48 AM
dodgequad05's Avatar
dodgequad05
Well I tried what you said and nothing happened at all when I pressed the tow/haul button while going 40, 45, 50, and 55. So where do I start to figure out how to get it working?
Old Jul 15, 2010 | 05:29 PM
dodgequad05
I went on a trip this past weekend up to the mountains and my truck was having a hard time getting up the hills. The best I could do was press and hold the accellerator down to the point that it would kick out of OD. The light doesn't come on when I press the button on the shifter. I checked for fuses in the engine compartment and I didn't see anything mentioning that function. What do I do now to get this working?
Old Jul 15, 2010 | 05:38 PM
Mega-Hemi's Avatar
Mega-Hemi
Unplug the wire running from your button in the column and see if you have continuity through it when you push it. If not your button is bad. You'll have to replace the whole shift ****. I've had to do it on a ram before.
Old Jul 15, 2010 | 08:36 PM
HemiLonestar's Avatar
HemiLonestar
I don't have this issue. OD off only for the '03.
Old Aug 24, 2010 | 05:03 PM
dodgequad05
How do you unplug the wiring from the button? Does the end of the shifter twist off?
Old Aug 24, 2010 | 06:48 PM
Mega-Hemi's Avatar
Mega-Hemi
I'm not 100% sure about the newer ones but the 2ng gen ones came as an assembly. You couldn't take the button off the end without breaking it. You'll have to follow the wires down the steering column untill you come accross a plug.
Old Aug 25, 2010 | 09:55 AM
dodgequad05
Alright I'll have to give it a try tomorrow to see if that will work.
Old Aug 31, 2010 | 11:02 AM
dodgequad05
Well, found the problem. It was unplugged under the dash. Plugged it in and now the Tow/Haul light goes on. So that's good. So with the 3rd gen Tow/Haul Mode just makes the trans shift firmer and at a later time, but does not disengage Overdrive right? When I pressed the button once, the light turned on, pressed it again and the light went off.
Old Aug 31, 2010 | 01:47 PM
Marx's Avatar
Marx
its shifts firmer and locks out 5th
