Transmission fluid
Old Oct 14, 2009 | 06:06 AM
Pysiek's Avatar
Pysiek
Default Transmission fluid
Should I change my transmission fluid?
My Dodge: 2002 Ram 1500 4WD. 98000 miles.
Old Oct 14, 2009 | 06:13 AM
abarmby's Avatar
abarmby
Yep.
Don't go for a flush.
Drop the oil, change the filters and replace/top up with new transmission fluid.
That way, you get to replace at least half the tranny fluid.
Apparently, don't know if it's an urban myth or not........?
Flushing high mileage trannys for the first time can fry em'.
That's why I believe, most people just drop the pan.
I dropped the pan and filter changed my 03 at 72K miles and she has 97K on her now.
Al.
Old Oct 14, 2009 | 06:27 AM
Pysiek's Avatar
Pysiek
So what you are saying is that I have to drop only half of the fluid? Can anybody help me with that? What tools to use? What transmission fluid? How to make it right?
Old Oct 14, 2009 | 06:59 AM
BEAR's Avatar
BEAR
By dropping the pan you will only change half the fluid. There is still old fluid in the TC and lines.
Old Oct 14, 2009 | 07:06 AM
MikeHTally's Avatar
MikeHTally
Ah, yeah. The book says every 30K. Make sure you get the right filter. Not sure what tranny you have, but often the filters are different for the 4x4s. Ditto on the "no flush". Too many miles on it now. You could let the pump flush it for you. Sounds more time-consuming, though.
Old Oct 14, 2009 | 07:14 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Asking should you change the fluid at 98k is like asking a cancer paitent if they what radiation medicine. Of course you need to change it!! ;-)
Old Oct 14, 2009 | 10:12 AM
Pysiek's Avatar
Pysiek
I'm asking because I heard somewhere that you should not do it.
So I should flush it or just drop the pan?
I found those instructions http://www.pavementsucks.com/tech-article-39.html
Old Oct 14, 2009 | 10:40 AM
HammerZ71's Avatar
HammerZ71
One of the weakest components in a Dodge truck is the automatic transmission. Keeping it cool and clean and not overworking it are the best things you can do for it.
I'd change the fluid, use a full synthetic and do it at least as often as the recommended intervals.
You can beat most Chrysler engines to death and not pay a price, but you don't keep up with maintenance on the tranny and you are asking for trouble...
Old Oct 14, 2009 | 11:15 AM
shadow11's Avatar
shadow11
Follow these instructions here and you will be fine http://www.60ateight.com/DodgeRam/
Old Oct 14, 2009 | 11:27 AM
abarmby's Avatar
abarmby
DROP THE PAN.......do not flush!
+1 on what weedahoe said.
Al.
