3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
so ive been having this prob for a few weeks now, it happened right after i did a seafoam treatment, but i suspected water in the fuel, it ran rough at first startup and around 1500 rpm cold, once warm it was fine, 2 tanks later and 2 bottles of lucas fuel injector cleaner and shes golden even has alot of her power back too! but today it misfired n 2nd going up a hill at 1500 rpms, jumped between 1500 and 1700 and i got a MIL i havent had a chance to get it read yet but im suspecting just a misfire code, ive also checked and cleaned the TB, checked plugs for fouling and they look good, anything thoughts on what els it might be? also this is an 04' 2500 5.7 auto thanks guys
Something you may want to check too, is that you don't have any moisture in the chambers where your spark plugs screw in. Sometimes that'll make it spark out and cause a misfire code to show up. This happens to me sometimes when I wash my truck with a pressure sprayer.
