Battery not holding volts
Old Oct 21, 2009 | 07:28 AM
dazza's Avatar
dazza
Default Battery not holding volts
Hi All
I have a 2003 Dodge Ram quad cab 5.7 Hemi here in the UK, if i dont use it for 3-5 days the battery goes flat, it has an alarm fitted and i am told its not that that is draining the power, how can i find out whats wrong with it, i haven't left the lights on and it has the Battery saver fitted which cuts off the power it the lights are left me!
Please Help
From Across the Pond
Darren
Old Oct 21, 2009 | 07:35 AM
nim81's Avatar
nim81
sounds like you need a new battery.
Old Oct 21, 2009 | 07:57 AM
dazza's Avatar
dazza
Sorry forgot to say i have just paid £300 quid for a new Ulimate Profromance battery, thats $480
Old Oct 21, 2009 | 08:27 AM
Lifted4x4Astro's Avatar
Lifted4x4Astro
If you have access to an ammeter, you can measure the current draw at the battery with the truck off. This will show you if there is a parasitic draw someplace. You can then remove 1 fuse at a time to see which circuit is causing the problem. A bad alternator will cause an excessive draw as well when shut off.
Old Oct 21, 2009 | 08:49 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yep, i agree on testing the current draw on it so you can narrow down what is causing the dead battery.
Old Oct 21, 2009 | 08:55 AM
BadHab1t's Avatar
BadHab1t
also check your alt fuse i had one in my old truck just blow from installing new battery which caused the alt to not charge battery? just an idea also most auto stores here anyway will test alternators for free....
Old Oct 21, 2009 | 08:58 PM
HemiLonestar's Avatar
HemiLonestar
Sounds like you got one out of a bad batch, is there a warranty?
Old Oct 22, 2009 | 09:03 AM
dazza's Avatar
dazza
Thanks for all your replys, no there is no warranty, i will do the battery checks with the meter and let you no the outcome, its been converted to LPG duel fuel and was wondering if the LPG computer is staying on! i have been told that there is a trickle charger that fits to the battery and plugs into the house mains that will give it 12volts but i would rafter check the cause first!
Many Thanks
From across the Pond
Darren
Old Oct 22, 2009 | 09:12 AM
dirtydog's Avatar
dirtydog
Moderate User
i would put on a charger in the mean time until you figure out what the problem is. Draining the power out of your battery on a regular basis is not good for it. it needs to keep a constant charge to last.
One thing you could do without much effort. Unplug the battery's positive terminal afte the battery if fully chagred and let it set for the few days if you can afford it. If the battery has full charge after then, you know the problem is from an accessory drain.
Also, i purchased an Optima battery for my Mustang. it went dead within 2 weeks. i got another one and the same thing happened. i found out later on that if you don't fully charge certain batteries, they will not "learn" to hold a charge and they go bad real quick. this is similar with Lithium type batteries used everyday. Those are reccomended to fully charge and then afte they are charged, try and recharge them again before use. this method actually teaches the battery to hold more of a charge and last longer. Although most batteries off the shelf are done this way from the factory. it's just that they sit on the shelf for a few months before they get charged again.
