Engine block heater, and Battery Blanket
Old Oct 23, 2009 | 05:40 PM
moosefire66's Avatar
moosefire66
Im not worried that it will be so cold that it wont start. Its just that I dont want to get an emergency call in the middle of the night, and do mach 3 in my truck on a completely cold engine. Thats my main concern.
Old Oct 23, 2009 | 05:53 PM
dunerider650's Avatar
dunerider650
If all your worried about is not hurting the motor than all you need if to have it plugged in.
Old Oct 24, 2009 | 12:34 AM
lxman1's Avatar
lxman1
Site Moderator
HUH?
Even one that goes in the bottom radiator hose will work for keeping the oil warm enough to make a bonsai run in the middle of the night.
Old Oct 24, 2009 | 01:08 AM
oneHEMI57's Avatar
oneHEMI57
This is what I ran on my Ford 460CID in the early '80s while stationed in the W north.
One heater pad on the trans pan and water heater circulator on the heater hoses.
http://www.amazon.com/Kats-13080-Alu...=pd_sbs_auto_3 Worked great for five years.
The heater, pushes and pulls as it heats the water (coolant).
Old Oct 24, 2009 | 02:58 AM
we_the_unforgiven's Avatar
we_the_unforgiven
Good idea. Typically we start plugging vehicles in here around 5-10 degrees or so depending on your vehicle. Find yourself a block heater or hose heater and plug it in. Unless your battery is weak, really you wouldn't need a trickle charger on the battery. I ran one on my Cummins but only in super cold (-20 to -40).
Old Oct 24, 2009 | 04:17 PM
davb673's Avatar
davb673
I had the dealer install a block heater shortly after I bought my truck. I like it. It gets down to 0 here (haven't seen lower yet), and I don't really need to use it, but I like to because I have a short drive to work and want things warmed up before I get there. Also saves some fuel as the warmup cycle is shorter... I've been in -8 and still no problems.
