Died just like that
Old Oct 23, 2009 | 10:35 PM
Pysiek's Avatar
Pysiek
Okay guys. Battery is good. Fuel pump good. Engine rotates(slowly) but will not start.
Old Oct 23, 2009 | 11:38 PM
ELVIS56's Avatar
ELVIS56
hey, if youve been cranking on the engine with a good battery and the engine is cycling slow maybe you should throw a charger on it for awhile to top it up. If that doesnt help then it sounds like an ignition/electrical problem. Do the dash lights dim when rotating the engine (after charging the battery fully)? What is the mileage on the truck?
Old Oct 23, 2009 | 11:40 PM
lxman1's Avatar
lxman1
Site Moderator
Check the battery cables. Both ends. sounds like a bad connection somewhere. Should turn over quickly with a good battery. If they check ok, the starter may be on the way out and not cranking fast enough.
On a side note, I have seen bad crank position sensors cause no spark and no spark.
Just for kicks, check all of the fuses in the power box under the hood.
Old Oct 24, 2009 | 11:26 AM
Pysiek's Avatar
Pysiek
Sometimes it sounds like it almost got it. But then just dies. Is my fuel filter located in the tank?
Old Oct 24, 2009 | 11:27 AM
dunerider650's Avatar
dunerider650
your fuel filter is located along the frame rail underneath the truck...go to the gas tank then follow the lines out until you get to the fuel filter
Old Oct 24, 2009 | 11:33 AM
dodgenitto's Avatar
dodgenitto
Mine is in the tank. Yours should be too.
Old Oct 24, 2009 | 11:41 AM
dirtydog's Avatar
dirtydog
Moderate User
ALl Ram filters are in tank. They are abnormal from most vehicles.
You sure you got spark?
Old Oct 24, 2009 | 12:26 PM
dunerider650
good to know....just assumed it would be like any other vehicle...guess not...what a pain
Old Oct 24, 2009 | 02:54 PM
lxman1's Avatar
lxman1
Site Moderator
Should last as long as the pump does. Most all gas stations have filters in the system between the tank and pumps.
Old Oct 25, 2009 | 10:58 AM
Pysiek's Avatar
Pysiek
I will check the spark as soon as possible. It's raining for 3 days in Chicago
