Roller Rockers
Old Oct 23, 2009 | 10:34 PM
rydesolow's Avatar
rydesolow
Default Roller Rockers
I have a 2002 5.9L v8 magnum. I'm looking for a good set of roller rockers.. Anybody have any experience putting these in? I want to go with a 1.6. I know I will need taller valve covers, that shouldn't be much of a problem.
I found a genuine mopar kit with aluminum rollers 1.6. Comes with everything, even pushrods. I think I can do the valve adjusting myself, I'm not too concerned with that.. Just wonder if anybody has toyed with different brands, experience in power gains, etc?
Let me know what you guys are thinking.
BTW: Stock Cam.
Old Oct 23, 2009 | 11:20 PM
Laramie1997's Avatar
Laramie1997
Stock rockers on the 5.9 magnum motors were 1.6..... We all seem to like Harland Sharp 1.7 rocker rollers. Even our section mod is featured on their home page. They are worth looking into.
Old Oct 23, 2009 | 11:42 PM
lxman1's Avatar
lxman1
Site Moderator
Yeah, no noticeable power increase from just switching to roller rockers and staying with the same ratio. Just a bit less friction/drag.
Old Oct 23, 2009 | 11:45 PM
Laramie1997
^ Yea, I think the main thing you would be going for by using the stock ratio is to get rid of the 5-7% variance between each rocker, right?
Old Oct 24, 2009 | 12:12 AM
Hahns5.2's Avatar
Hahns5.2
Unless you're using an aftermarket cam there's no reason to use 1.6s or adjustables. Harland Sharp 1.7 pedestal mount rockers bolt on and fit under the valve covers.
Old Oct 24, 2009 | 12:38 AM
lxman1's Avatar
lxman1
Site Moderator
Yep, but I would go with the HS pedestal mounted 1.7's as well.
Old Oct 24, 2009 | 12:40 AM
lastrights's Avatar
lastrights
go with 1.7 harland sharps, they act as a mini cam , its easy install and noticible gain down low, you may want to look into the fastman throttlebody too...
Old Oct 25, 2009 | 02:53 PM
rydesolow's Avatar
rydesolow
Yeah I thought we had 1.5's, my fault. So the 1.7's fit and give a little more down low? I think I'll check them out then, I think that's next on my list. How well does the fastman throttlebody work?
Old Oct 25, 2009 | 11:58 PM
lastrights's Avatar
lastrights
works well www.thefastman.com you want the 52mm you get 80 back when you send yours in after installing his..
the 1.7 changes the sound off you exhaust too, a lil more lope
Old Oct 26, 2009 | 02:27 PM
rydesolow's Avatar
rydesolow
Awesome, that's what I'm going to go with
