DIY Rear diff fluid change?
Old 10-25-2009, 07:38 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Yeah, no modifier if using RP. Maybe the level from the fill hole is different for certain years but Im fairly sure for my 04 its was 1/4" per AllData.
Old 10-26-2009, 03:00 AM
thebean's Avatar
thebean
thebean is offline
Thanks everyone! Dirty, Weedahoe, davb - you guys are great. I'll probably change my fluid next weekend, will let y'all know if I run into any snags so you can bail me out. :-)
Old 10-26-2009, 07:37 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
You cant screw it up. At first, just make sure you take all the bolts out except the top two. Just loosen them real good and then place your oil pan under the rear end. Pop loose the cover so it "leaks" all or most of the fluid in the pan so you dont make a mess. Then take those last two bolts out and inspect/clean everything. Good luck and I am sure you will do fine.
Old 10-26-2009, 11:31 PM
JOHNSN10's Avatar
JOHNSN10
JOHNSN10 is offline
question-all u guys say to fill so its a certain amount below the plug but how do u know when its at that certain amount below it? u cant see it so how do u know?
Old 10-27-2009, 02:07 AM
Dawizman's Avatar
Dawizman
Dawizman is offline
Stick your pinky finger in the hole and make an educated guess. There isn't really an exact science to it.
Old 10-27-2009, 04:46 AM
abarmby's Avatar
abarmby
abarmby is offline
Remember any of you with a DTT, use only Dino oil.
No synthetics.
Al.
Old 10-27-2009, 05:38 PM
chambers's Avatar
chambers
chambers is offline
No synthetics.
Al.
Well I have read that on some sites but on eaton's site in the manual for the truetracs it says "The TrueTrac differential is designed to operate in those lubricants recommended by the vehicle/axle manufacturer for conventional differentials." I don't have any experience one way or the other w/ the DTT's but I do plan on putting one in my truck soon.
Quick Reply: DIY Rear diff fluid change?
