Overhead wacked out
Old Oct 24, 2009 | 11:41 PM
cheapbeater's Avatar
cheapbeater
Default Overhead wacked out
My overhead computer thing has been giving me some problems lately. First i noticed that the gas mileage would reset every time i shut the truck off, now the temp readout says 130*F... it snowed today so I dont think its that hot out
Is there a memory fuse like a stereo has? I dont think its a wire because it seems to be getting power just fine...
any idears?
Old Oct 25, 2009 | 01:18 AM
lxman1's Avatar
lxman1
Site Moderator
It is controlled by the PCM. You might do the unhooking the battery for 1/2 hr with the head lights turned on (helps drain any remaining power in the memory circuit) and see if it helps.
Old Oct 25, 2009 | 02:33 AM
cheapbeater
controlled by the PCM 'ey? it just started acting up after i reset the PCM...
tomorrow i will try the battery trick, and if that doesnt work i will reset the PCM again.
thanks
Old Oct 25, 2009 | 01:18 PM
lxman1's Avatar
lxman1
Site Moderator
Yep. Did you notice that the display goes to -- when programming a tune? Mine does with my DSP. The PCM uses the sensor it to determine ambient air temp. The display is just a driver bonus
Old Oct 25, 2009 | 01:39 PM
cheapbeater
yess, it does that when i program with my sc too. i know its just a driver bonus, but im kinda **** about stuff like that... but im not gunna tear stuff apart to diagnose it
Old Oct 25, 2009 | 01:51 PM
lxman1's Avatar
lxman1
Site Moderator
No. I look at mine all of the time. I would want it fixed too. It's just a driver bonus as in since the PCM uses ambient temp in it's calculations, why not add a display in the cab?
Hope it fixes it. I never realized how much I look at mine until I drive something without it
Old Oct 25, 2009 | 02:55 PM
cheapbeater
I just did the battery trick and it worked!!
Thanks lxman!!
