5.7 to 6.1 ignition conversion kit finished
Old Oct 26, 2009 | 09:27 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Originally Posted by lxman1
That's what I thought. Cool. I just wonder why they call the ignition the 6.1L upgrade when it is the same as the 06-08 MDS ignition? No big deal I guess. 6.1L makes it sound faster I guess
Youre right about the calling of the 6.1 kit. IDK why honestly and as I was discussing with Motorhead, I was looking online today and found those same coils for about $21 each. So thats only about $170 total for coils. IDK how much the VCs cost I bet you could find them at a decent price. I found the harness's also but not a price but again, im sure they wont break the bank. My point is that this kit from Hensons is like 450ish. If you really wanted to Im sure you could piece one together for less.
Originally Posted by draco8494
lol, i just did the shortie taylor wires, im not all that into the wiring scene, looks good tho, im REALLY wanting to take my valve covers off to paint them or something, their crazy nasty, all pitted n stuff
You can always buy my old VCs, clean them and paint them, swap them out on yours and then sell yours.
Old Oct 28, 2009 | 11:21 AM
motorhead426's Avatar
motorhead426
All prices are from www.moparpartsamerica.com, which are about %25 less than retail from your local dealer.
6.1L Valve Cover - PN# 5037531AC - $52.38 x2 = $104.76
6.1 Ignition Coil - PN# 56029129AB - $21.10 x8 = $168.80
Ignition Coil Connector - PN# 5019952AA - $17.02 x8 = $136.16
Total = $409.72
When I ordered mine a few months ago, the individual prices were more. The total separately was $454.22. Then add some for S&H.
My total price just for the conversion was $425 w/free shipping. I think it wasa good deal. I'm not going to stress about a few bucks...
Old Dec 12, 2019 | 08:06 PM
Whitetrash04derdge's Avatar
Whitetrash04derdge
As some of you know, I was going to do my conversion kit this weekend and thats not only exactly what I did, but thats ALL I did.....
Anyway, the kit is located HERE for those who wanna see it. This really looks good and cleans things up a lot under the hood. The pass side VC is a biotch to get off. But once you get it and the other side swapped out, the rest is super easy. Unfortunately Ive got to take it all back apart in a few weeks so I can put in my cam. But this will also make room for my 6.1 intake I will do later on.
On a side note, I cant help but wonder if this will make me run slightly more rich because I am now firing both plugs in one cylinder simultaniously v/s one on each side of the engine. You know the OEM coils would fire the one the coils sits on top of and the other plug in another cylinder that the wire goes to. So IDK about that one but I was just wondering.
Anyway, its all done. It doesnt run any different and no power added. This is just a mod for looks.
http://cid-fb87bd8396fbfbf4.skydrive...1%20conversion
Is this still a thing? I put together everything I need from the junkyard (I think) but I'd need some info before I start. I see this is a pretty old post but I'm hoping for a reply
Old Dec 13, 2019 | 01:24 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
Well if you're good with soldering, etc then you can hack up your harness. If not, they make pigtail adapters to adapt your stock plugs to the newer style coils:
Old Dec 13, 2019 | 01:48 PM
Whitetrash04derdge
I got no problem with splicing in the pig tails and all that fancy stuff but I'm just wondering what wires go where for the new coil packs. I'd be upset if I had the two wires backwards but I guess I could use those push in pigtails to easily switch them. So this is a pretty straight forward swap over?
Old Dec 14, 2019 | 03:27 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
Pretty much...if you can find anyone with an 06 or newer Ram or LX you can see how they're setup.
Old Dec 15, 2019 | 07:11 AM
RedTruck-VA's Avatar
RedTruck-VA
It is simple, there are two wires. One has 12v on it and powers all the coils. The other wire is color coded specifically for that coil and goes to the pcm. The injector's are powered from the same source (ASD) and are wire the same. One wire is power and the other color coded for the specific injectors. Once you unwrap the harness it will become clear which are power and which are pcm wires.
Old Dec 15, 2019 | 11:58 AM
Whitetrash04derdge
Does it matter what pin on the new coil packs gets power or pcm? If I accidentally put them backwards without knowing will it fry my coil?
Old Dec 15, 2019 | 04:35 PM
Shouldn't matter, but, I would make the effort to keep polarity the same as it was. It's just a coil. Apply voltage, and it creates a magnetic field, remove the voltage, the magnetic field collapses, creating voltage in the secondary windings. And you get a spark.
