replaced head gasket and still doesnt start
Old Oct 27, 2009 | 06:27 PM
thataway5000's Avatar
thataway5000
Default replaced head gasket and still doesnt start
i have a 2002 dodge ram 4.7, ive replaced the head gasket and it still doesnt start. there are also no error codes. the truck sat for 6 months before i replaced the head gasket. any ideas on where to check next?
Old Oct 27, 2009 | 07:08 PM
dirtydog's Avatar
dirtydog
Moderate User
Got spark? Bad headgasket will still allow the truck to run, just not at it's peak performance. Check the plugs and make sure you've got fuel getting to the injectors.
Old Oct 27, 2009 | 07:18 PM
thataway5000
im getting spark, havent checked fuel yet. so would i pull one of the injector plugs to check the fuel?
Old Oct 27, 2009 | 08:01 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You could spray some starter fluid in the TB. Thats how I would start testing. Have you checked all of your fuses?
Old Oct 27, 2009 | 08:08 PM
thataway5000
no which ones should i test
Old Oct 28, 2009 | 08:13 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Sry, but test what?
Old Oct 28, 2009 | 09:14 AM
dirtydog's Avatar
dirtydog
Moderate User
I think he's confused. You said "test" the fuel by spraying starter fluid in the throttlebody and I think he thought you meant test the fuses...lol
There is a shrader valve just like a valve stem on a wheel. You can remove the cap and press the plunger down and if fuel squirts out, then you have fuel pressure. The valve is on the fuel rail, possibly on the pass. side. maybe it has a green cap?? I never really paid much attention. Just make sure your on the fuel rail on not on an AC line which is kinda obvious.
I would put a rag under the valve and not look at it because it may or may not squirt out like a banshee? I've always had it trickle out because you only need to press the plunger down just a little bit. Not all the way. it's just like letting a tiny bit of air out of your tires.
Old Oct 28, 2009 | 09:18 AM
dirtydog's Avatar
dirtydog
Moderate User
One more thing. Turn your key to ignition position without trying to start. Let it sit there for about 5 sec so that the fuel pump can prime and build pressure. otherwise if your truck has been sitting, you may not get much or if anything out of the valve at all. Make sure you turn the key OFF before you touch the valve.
Old Oct 28, 2009 | 10:12 AM
thataway5000
i was saying which fuses should i check.
Old Oct 28, 2009 | 10:41 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
All of them.
