hemi oil change.
Old Apr 7, 2005 | 01:00 PM
kitesurfer's Avatar
kitesurfer
Default hemi oil change.
i just read this on a motorcyle forum. this guy has an 05 hemi (like mine) and says the owners manual requires 5w20or 0w20 oil and the factory oil filter due to psi valve blow by. he says that if he puts in 10w30 or another filter, then the engine will knock. anyone know about this? i'm due for my 1st oil change.
Old Apr 7, 2005 | 01:14 PM
thump186's Avatar
thump186
Default RE: hemi oil change.
its not due to the blow by and factory filter is not required. it is due to allowing the multi dispacment to operate properly. using 5w20 is the way dodge accomplished making the system work for them.
Old Apr 7, 2005 | 01:36 PM
kitesurfer's Avatar
kitesurfer
my 2005 ram does not have that multi displacement --that's 4cyl/8cyl, right? so i should have no problems with the oil and filter, right?
Old Apr 7, 2005 | 01:38 PM
TeeWJay426's Avatar
TeeWJay426
That's correct- use the 5W30 as recommended in the manual and you'll be fine.
Old Apr 7, 2005 | 02:11 PM
Wideglide2K's Avatar
Wideglide2K
How often is everyone changing their oil. I just got my 05- 2500 two weeks ago. I read the book for how I drive and conditions it states every 6000... I have change my oil in my old 96 1500 every 3000. But I have to say when I did it every 3000 that old was clean.
Old Apr 7, 2005 | 02:36 PM
moparturd's Avatar
moparturd
I'm changing my Mobil 1 every 5K, with the filter.
Old Apr 7, 2005 | 03:25 PM
osteodoc08's Avatar
osteodoc08
Mobil 1 5W/30 with quality filter (either Mobil brand or PureOne, whichever is in stock and cheaper) ever 5000 miles.
Old Apr 7, 2005 | 04:15 PM
WingViper's Avatar
WingViper
Do you guys stick with the 5W30 all the time or do you use 10W30 during the summers? I was raised to switch to 5W only during the winter, but I'm curious about my new HEMI. Should I switch over and stick with it?
Old Apr 7, 2005 | 04:24 PM
DonG's Avatar
DonG
I've read the lighter oil helps reduce the occurance of the "hemi tick". I wouldn't think it has anything to do with the multi displacement since none of the rams come with it. I think there is a SB out for earlier hemis to run this lighter oil. I've seen where several have gotten rid of the tick by running it. I run Mobile 1 5w30 and change every 5000.
Old Apr 7, 2005 | 04:37 PM
moparturd's Avatar
moparturd
I stick with the 5w-30 since it basically covers the same range of temperatures as the 10w-30, but flows better when cold.
