Transmission Maintenance Assistance, please
Old Nov 7, 2009 | 04:53 PM
mbramble's Avatar
mbramble
Default Transmission Maintenance Assistance, please
I have a 2004 2WD Dodge Ram with 3.7L and Multi-Speed Transmission. Codes in glove box say:
G8 Transmission All 4sp
G4 Transmission Multi-speed
HA Torque Converter Lock
What model transmission do I have?? I see references to 45RFE/545RFE in the maint schedule and to 46re, 47re, 48re, 454rfe and 545rfe, etc. in the Haynes manual I have.
I want to change the tranny filter and fluid instead of paying the dealer all that money again. Is there only the standard flat type AT filter to replace or is there also one that looks like an oil filter -- in this tranny??
The maintenance schedule in the owner's manual states:
Drain and refill auto tran fluid and change main sump filter (45RFE/545RFE only)
at 30/60K miles but adds:
"and spin-on cooler return filter (if equipped) for the 90K mile entry.
I am currently sitting at 60K but am wondering if my tranny is "so equipped" with the spin-on cooler return filter.....
How much fluid does it normally take to refill the transmission??
Anyone know what part number to get at AutoZone or Advance Auto, or Pep Boys??
When I go to dodgepartsonline.com they show:
Filter, ram 1500, 45rfe 02-05 $33.80
Filter, ram 1500, 48re 02-07 $20.85
for a 2004 Ram 1500.
Thanks for any assistance
Old Nov 7, 2009 | 05:44 PM
cheapbeater's Avatar
cheapbeater
hmm, i thought the G8 was a manual... haha. I'm no help at all...
Old Nov 7, 2009 | 09:24 PM
lxman1's Avatar
lxman1
Site Moderator
45RFE I believe. The 545RFE is the 5 speed auto.
Old Aug 14, 2010 | 11:43 PM
dale hanna's Avatar
dale hanna
can anyone tell me what a P1740 code is
Old Aug 15, 2010 | 01:37 AM
freestyledude's Avatar
freestyledude
Google is your friend
And to the O.P. you may be able to phone the dealer and ask, they'll be able to pull up whether it has the filter or not, and should also have the specs for the fluid capacity. I think you'd have the 48re but I'm not 100% sure on that
Old Aug 15, 2010 | 02:45 PM
mptoad's Avatar
mptoad
wow...nice hi-jack.
Old Aug 15, 2010 | 06:10 PM
master tech's Avatar
master tech
Site Moderator & Tech
The 3.7L would have a 45RFE/545RFE depends on the software thats in the controller. And P1740 code is a lock up no rpm drop code.
Old Aug 16, 2010 | 12:23 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Always check the FAQs HERE
B/C/P/U 2004-2007 codes in full details from AllData
