Trick to turning off the seatbelt dinger?
Old Nov 15, 2009 | 09:50 AM
Rotdog98's Avatar
Rotdog98
Default Trick to turning off the seatbelt dinger?
I have an 07 ram was wondering if there was a way to eliminate the dinging of the seatbelt I am sure this has been asked before havent been on here in a while thanks.
Old Nov 15, 2009 | 10:07 AM
hemiquad4x4's Avatar
hemiquad4x4
I found it in my owners manual and turned mine off but don't remember the sequence. The sound goes away but the light will come on in the dash.
Old Nov 15, 2009 | 10:13 AM
Kyle718's Avatar
Kyle718
wear you seatbelt......
shut all doors
turn off ignition
buckle seat belt
turn on ignition
buckle and unbuckle 3 times
watch lights every time it ends with seat belt buckled
turn off ignition
you should hear 1 chime and it is done this must be done in less than 60 seconds also you have to let seat belt retract some when buckling and unbuckling
Old Nov 15, 2009 | 10:56 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I used a electrical tap and bridges the two wires on the seatbelt plug. This was done years ago before I found out there was a way to do it through the ign but since it was done I left it alone. Here is GA and in trucks we do not have to wear belts.
Old Nov 15, 2009 | 11:22 AM
tlawre87's Avatar
tlawre87
1. With all doors closed and ignition off, buckle your seat belt.
2. Turn the ignition on and wait for the seat belt light to go off.
3. Within 60 seconds of turning the ignition on, unbuckle and the re-buckle the drivers seat belt at least 3 times with 10 seconds, ending with the seat belt buckled.
4. Turn the ignition to the LOCK postion. A single chime will indicate that you have successfully completed the programming.
That was for my 08 but it should work for you
Old Nov 15, 2009 | 11:58 AM
lxman1's Avatar
lxman1
Site Moderator
I wear mine. No light or ding
Old Nov 15, 2009 | 11:18 PM
RSDodgelover's Avatar
RSDodgelover
Seat belt extension !
Old Nov 15, 2009 | 11:47 PM
Dubsport's Avatar
Dubsport
Works for me... its been the law up here for years!
Old Nov 16, 2009 | 02:18 AM
ramracing4.7ltr's Avatar
ramracing4.7ltr
id say , go ahead and pull the seatbelt dinger ,fuse!
Old Nov 16, 2009 | 05:24 PM
draco8494's Avatar
draco8494
mine just stopped doing it?? but i normally do wear it, cuz its the law....i havent been pulled specifically for that but if they pull u over for something els thell get you with it
