is this normal?
Old Nov 15, 2009 | 04:44 PM
JOHNSN10's Avatar
JOHNSN10
Default is this normal?
i wanted to change the spark plugs today and when i took the air intake out i thought it may be a good idea to clean the tb so i took all the bolts out turned it over and saw an oil type residue on it,now is this normally supposed to happen and eventually turn real dark and stick to the tb or is this oil? when i took the air filter out it to had a small amout of oil looking residue as did the small tube going in to the air box.the dealer did detail the engine and it was shinny looking,so is this just the oil from what they used that over timer maybe got into it somehow? check out the pics and let me know what u think.also real quick- whats the easiest way to remove that little air hose connected to the tb? i twisted it and pulled on it and tried to use a flat head screw driver but i couldnt get it off
Old Nov 15, 2009 | 05:09 PM
dirtydog's Avatar
dirtydog
Moderate User
It's just oil. Happens over time. To make it to your airfilter is a bit of a journey, but i would change your PVC valve if you haven't already. Air filter is fine.
Old Nov 15, 2009 | 05:18 PM
JOHNSN10's Avatar
JOHNSN10
i was told by the guy at advanced auto that my 05 ram doesnt have a pcv valve.
Old Nov 15, 2009 | 08:44 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
Nothing out of the ordinary having that build up on the back of your TB.
Old Nov 15, 2009 | 08:47 PM
SilverBullet08's Avatar
SilverBullet08
hes wrong bc i just cleaned my pcv valve couple weeks ago... and its in the manual...
Old Nov 15, 2009 | 08:53 PM
JOHNSN10's Avatar
JOHNSN10
where is the pcv valve on a 4.7?
Old Nov 15, 2009 | 10:57 PM
chambers's Avatar
chambers
It should be on the neck of the oil filler tube. It's a plastic cylinder shaped at a right angle that connects to the oil breather hose. You just have to rotate it 90 degrees counterclockwise and pull straight out to remove it. It's like $5 for a replacement.
Old Nov 16, 2009 | 07:55 PM
JOHNSN10's Avatar
JOHNSN10
Ok so if advanced auto says my truck doesnt have one,where would i get one?
Old Nov 16, 2009 | 08:09 PM
MikeHTally's Avatar
MikeHTally
What a surprise. 4.7 PCV valve is on the filler neck. 5.7 is on the passenger side of the motor near the firewall.
Old Nov 16, 2009 | 08:38 PM
fasttruck860's Avatar
fasttruck860
Order it online or through another store or the dealer. Advanced Auto told me that it wasn't serviceable.
