Changing to 4x4
Old Nov 20, 2009 | 01:38 PM
CubanBlood's Avatar
CubanBlood
Exclamation Changing to 4x4
My 2002 Ram 1500 has the manual 4x4 stick. On the owners manual does not specify how to change between 2, 4L, and 4H. do i have to stop and put en neutral to change or i can do it on the fly? Sorry for the stupid question.
Old Nov 20, 2009 | 01:46 PM
cajun ram's Avatar
cajun ram
u have to stop
draco8494's Avatar
draco8494
can do it on the fly for 4HI but have to be at a stop for 4LO , also if your doing it on the fly you cant be spinning the rear tires and trying to switch it to 4HI it will grind
Old Nov 21, 2009 | 10:35 AM
SweeTbone's Avatar
SweeTbone
4WD HI you can be going up to 55 MPH to engage it on the fly. Make sure your tires are not spinning and let off the gas while you switch. 4WD LO you can be stopped and transmission in Neutral, but I've read that while you're in Neutral you should try to be rolling around 3 MPH just so gears don't clash while you engage it and your top speed in 4WD LO will be like 25 MPH.
Old Nov 21, 2009 | 11:41 AM
kx250frider617's Avatar
kx250frider617
i don't get this: You can engage at 55 mph but make sure the tires are not spinning?
Old Nov 21, 2009 | 11:51 AM
SweeTbone's Avatar
SweeTbone
Like losing traction spinning. Basically don't stay in the throttle while you engage it. Always let off the gas before engaging. Don't start fishtailing, keep your foot on the gas and try to engage it.
Old Nov 22, 2009 | 02:59 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
agreed. 4hi can be on the fly as long as you aren't spinning the rears faster than the front.
4 low you engage doing slow roll.
Old Nov 22, 2009 | 03:12 PM
lxman1's Avatar
lxman1
Site Moderator
Your tires are spinning at 55mph? LOL
Hows about, breaking traction. That should make more sense.
Old Nov 22, 2009 | 03:27 PM
xfeejayx's Avatar
xfeejayx
well put. you can do it under a bit of power too if you have to. but best practice is to let off the gas.
Old Nov 22, 2009 | 04:29 PM
CubanBlood's Avatar
CubanBlood
Thanks guys. I was looking through the books and found the manufacture guide on how to do it.
