check engine light
Old Nov 20, 2009 | 05:23 PM
shawks's Avatar
shawks
Default check engine light
recently my 06 1500 quad started spitting and hesitating, then the check engine light came on. I ended up taking it to dodge to see what was going on. they said i needed to do plugs and a computer update (has 65000 kms). so i did that. It was fine for about 3 days then the check engine light came on again. This time with no driving problems at all. I took it back in and they said the code was telling them it was the cataylic converter, but they were hoping that it was just a computer glich, and turned it off and sent me on my way. 2 days later the light was on. Again they said it was the converter and it needed to be replaced. Now i have taken it for an E-test and it passed with flying colours, and i have no symptoms of a faulty converter, but the light is still on.
Anyone with any ideas before i have to shell out 1700 bucks for a new converter!!!??
Old Nov 20, 2009 | 05:34 PM
chefred112's Avatar
chefred112
can you give us the code? that the engine light produced? any engine mods?
Old Nov 20, 2009 | 05:49 PM
truckin151's Avatar
truckin151
Faulty O2 sensor or wire, more than likely the rear O2's if its saying your Cats bad.
Old Nov 20, 2009 | 05:50 PM
truckin151's Avatar
truckin151
Also $1700 for a new Cat is WAY to high, you can get NEW high flow magnaflows for $60-$80 a peice.
Old Nov 20, 2009 | 10:53 PM
lxman1's Avatar
lxman1
Site Moderator
I'm thinking bad rear O2 sensor as well.
Old Nov 20, 2009 | 11:31 PM
tlawre87's Avatar
tlawre87
Cycle the key and find out which code it is. That will help to figure out what it is. Does sound like a bad rear 02 sensor.
Old Nov 21, 2009 | 02:42 AM
05hemipwrd's Avatar
05hemipwrd
should be under warranty. emissions warranty is alot longer than regular warrenty....actually i think its close to double
Old Nov 21, 2009 | 10:23 AM
shawks's Avatar
shawks
i dont know what the code is, how does the key cycle work, 3 times on and off ? I was thinking that it might be a sensor as well. An emissions test would still come out ok with a bad sensor would it not. and it would with a faulty converter.
Old Nov 21, 2009 | 04:37 PM
truckin151's Avatar
truckin151
If the rear sensor was bad it would still pass a sniffer test cause the cat would still be doing its job. If the cat was bad it wouldn't pass.
Old Nov 21, 2009 | 06:21 PM
shawks's Avatar
shawks
Well I think i am going to try replacing the rear sensor and see what happens. Thanks for all the help.
