Stock Tires
Old Nov 30, 2009 | 06:00 PM
02Steve1990's Avatar
02Steve1990
Alright, for the terra grapplers, what exactly am I looking at if I want to use my stock rim..for example one tire size is LT235/80R17 E 120R..what do all these numbers and letters mean exactly? Is the 17 the size of the rim the tire requires or something? I want to go a bit bigger than stock but something I can fit under stock height with my stock rim, so what exactly am I looking at here? lol
Old Nov 30, 2009 | 06:06 PM
02Steve1990
double post
Old Nov 30, 2009 | 06:12 PM
02Steve1990
triple post
02Steve1990
quadruple post (record?)
SilverBullet08's Avatar
SilverBullet08
https://dodgeforum.com/forum/3rd-gen...le-review.html
or 285s just dont know if you would need a level to fit that size
Old Nov 30, 2009 | 06:52 PM
05RamMan's Avatar
05RamMan
Dude, post key stuck? anything up to a 305 will fit your stock rim and most likely not rub even at stock height.
Here is a link to translate your numbers into an overall diameter.
http://www.discounttire.com/dtcs/infoTireMath.dos
I really like 295/70/17's (33's) They are just about the right size and width.
As far as the rest, Not trying to be an ****, but,
Old Nov 30, 2009 | 07:25 PM
V_Scapes's Avatar
V_Scapes
definatly get rid of those goodyears soon. got exactly 40k from mine when i blew a belt in one of the rear tires which can turn into a dangerous situation.
Old Nov 30, 2009 | 08:56 PM
lxman1's Avatar
lxman1
Site Moderator
BFGoodrich Long trail t/a's from Sams club!!!
Example 275/60R20
275= mm wide
60 = % tall as they are wide (aspect ratio) Sidewall is 60% as tall as the tire is wide (X 2 which means top and bottom)
R = Radial
20 = rim diameter
The E is the load range of the tire usually.
Old Nov 30, 2009 | 09:42 PM
codiac's Avatar
codiac
Example 275/60R20
275= mm wide
R = Radial
20 = rim diameter
Do you like the Long Trails? I'm in the same boat, but I've got a Jeep to trail ride in, so I want something good on the highway and in weather. The wrangler's weren't horrible, lasted 50k, but traction has been getting bad the last 10k or so. I'll probably end up at Costco getting the Long Trail T/A tours, but am open to options.
Old Dec 1, 2009 | 04:49 AM
05RamMan's Avatar
05RamMan
BFGoodrich All terrains 315/70/17's I have now, I like em, Very stout tires not to much noise and good traction.
