Huge Sale On TQ Converters!!!
Old Dec 1, 2009 | 10:38 AM
  #21
OlDirtyJohn's Avatar
OlDirtyJohn
i got the email from Bob as well. just in time for me. just gotta hope my bonus check hits soon.
Old Dec 1, 2009 | 01:55 PM
  #22
truckin151's Avatar
truckin151
I was just about to post this up when I checked my email last night. Its a hell of a deal!!! And yes bullet, I love the TC more than the 4.56's, still THE best mod to date
Old Dec 1, 2009 | 01:56 PM
  #23
SilverBullet08's Avatar
SilverBullet08
yea thats what i thought. any advice on the install? any specific tools i would need thanks
Old Dec 1, 2009 | 02:02 PM
  #24
truckin151's Avatar
truckin151
A LIFT, a really really long socket extention to unbolt the top bolts of the trans, impact gun, trans/engine jack....
If you do it on the floor be prepared to have it down for a weekend cause with all the bolts you have to get out and other things you have to unhook from the trans, its going to take a long time. I think it took us around the 6hr mark to get mine in on a lift (but that was also letting it cool down and doing the trans service as well).
Old Dec 1, 2009 | 02:07 PM
  #25
SilverBullet08
well crap i dont have a lift or some of that other stuff
Old Dec 1, 2009 | 02:10 PM
  #26
truckin151's Avatar
truckin151
Neither do I... Make some friends with some of the guys in your area, maybe one of them has a lift or put one in before that can lend a hand. Thats how I got mine in.
Old Dec 1, 2009 | 02:13 PM
  #27
SilverBullet08
yea. well i could put it on jackstands to raise it up alittle higher. how hard is the actual install? think i could do it lol
Old Dec 1, 2009 | 02:23 PM
  #28
truckin151's Avatar
truckin151
Lets see, you remove the drive shaft, unbolt the the trans, remove all electrical connections, put a jack under the trans to support it, remove the crossmember supporting the trans, back the trans straight back far enough to get to the converter, pull the converter off without spilling trans fluid everywhere, fill the new one with new trans fluid (not sure how much it takes but it'll be a bit), slide it on, and put everything back together.
On that note though, you should also get a larger trans cooler too. From what I have read and heard running a higher stall converter can make the trans run hotter that normal, with mine Im running the same temps as I did with the stock configuration.
Old Dec 1, 2009 | 02:55 PM
  #29
truckin151's Avatar
truckin151
Some usefull info if you are really looking into doing this.
https://dodgeforum.com/forum/3rd-gen...ter-is-on.html
https://dodgeforum.com/forum/3rd-gen...new-parts.html
Old Dec 1, 2009 | 03:56 PM
  #30
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
but you said it'd be a biatch with 4wd. also, says the converter is for engines with 440 ft.lbs or more.
