Trans. not shifting
Old Dec 1, 2009 | 08:46 AM
t5000's Avatar
t5000
Default Trans. not shifting
I need help. I haven't driven my 2004 Ram 1500 for about 2 months as I use my other car normally. Today I needed it as my wife is using my car. I started it and shifted into reverse but the engine just revs as if i'm in park. I've tried drive, low1 and 2 but nothing. I only have 19,000 miles on it and it was working fine when I parked it in my driveway. Any ideas?
Old Dec 1, 2009 | 09:33 AM
tuned93's Avatar
tuned93
low tranny fluid maybe?
Old Dec 1, 2009 | 10:01 AM
t5000's Avatar
t5000
I checked the fluid level and it's fine. The tranny fluid doesn't smell burnt and looks fine also.
Old Dec 1, 2009 | 10:12 AM
tuned93's Avatar
tuned93
linkage?
Old Dec 1, 2009 | 10:24 AM
RubberFrog's Avatar
RubberFrog
Fluid drained out of the torque converter. Let it idle for about 20 minutes and try slowly shifting it through the gears.
Old Dec 1, 2009 | 01:43 PM
t5000's Avatar
t5000
ok linkage is attached and shifting, I crawled under and checked it while my daughter shifted gears. I just started it and i'm letting it run for the 20 minutes now. Then i'll try it again, thanks.
Old Dec 1, 2009 | 02:35 PM
Ice-Forever's Avatar
Ice-Forever
Haha that just gave me a bad image. Shifting through gears while someone is laying under ur truck.
=X
Old Dec 1, 2009 | 02:45 PM
t5000's Avatar
t5000
I parked my jeep directly behind my truck an inch or so off my bumper just in case it shifted into gear and she took her foot off the brake.Well I tried running it for a 1/2 hour then tried shifting it into gear but still nothing. I'm able to engage 4wd and 4wd low but it still doesn't move. I wasn't able to shift the t-case into neutral though, the neutral light just blinked, you think this maybe something electrical or possibly a sensor? I have no idea.
Old Dec 1, 2009 | 04:02 PM
2006RAMHEMI1979's Avatar
2006RAMHEMI1979
did you check the linkage inside the truck?
Old Dec 2, 2009 | 09:00 AM
t5000's Avatar
t5000
No didn't check linkage inside truck but figured it was working since it's shifting on the side of the transmission. A friend of mine mentioned a parking brake pin inside the trans. that might have broken. Anyone hear of this before?
