Trannys gone
#21
#22
i got the transmission fluid flushed at my mechanics. i dont believe they removed the pan. now it is leaking all over the bottom. hardly any left .
i didnt think to check the fluid level until it started slipping and the check engine light came on. i just had it done and wouldnt have seen any reason to check it.
so dodgenitto u are right- mechanics flushed the trans oil, now its leaking horribly,very very low trans oil left in it, transmission slipping/burning smell , check engine lights on.
Thanks, but I bought them from a friend who works at dealership. Got them both with a front axle seal for $39
#23
no we were just working on it in the dark but i mean the entire thing is just covered. its not dripping on the ground tho.
another thing i was thinking maybe if i do need to replace the tranny, was to try to get one off of a wrecked ram? maybe try to save money or is this not the place to try to take shortcuts?
#24
But if it was your mechanics fault then THEY need to buy you a new one, or a re-built one at the very least.
#25
true but you know how mechanics are, they will say anything to get out of it. ill keep you guys posted on how it turns out tomorrow.
#26
To the OP. If your mechanic wont make it right and you end up holding the candle, I saw a couple transmissions on ebay the other day. They come out of wrecks and there were 2 of them for $725 a piece and another hundred or so for shipping. Might help until you can save to put something better in there.
#27
Second option pay an attorney a couple hundred for a phone consultation with him and he will probably settle with you then.
#28
#29
my truck had the tranny go out just recently i bought it about 4000 miles ago and then all the sudden it the truck started huntin for gears then it went completly out i checked the fluid level the day before it went out and it was just fine, and it was burnt. and then when i was driving the next day it completly went out, and i checked the fluid and it was completly burnt smelled terrible. does anybody know which transmission the 02 1500 with the 5.9 long bed 4x4 has i dont know if the long bed has anything to do with it or not. thanks
#30
