Arm and a Leg
Old Dec 15, 2009 | 03:22 PM
OlDirtyJohn's Avatar
OlDirtyJohn
wow, you are lucky weed. thats a killer deal. and i really do love having a 2500, even though it seems like most parts cost quite a bit more. my only regret is that mine isnt 4wd. but for $8000 out the door for a truck with less that 60k on it, how could i say no?
Old Dec 15, 2009 | 03:24 PM
draco8494's Avatar
draco8494
lol yeah i paid 18K fer mine.....just 4x4 same mileage too
Old Dec 15, 2009 | 04:00 PM
ramhunter9's Avatar
ramhunter9
mine was ordered with 4:10's so i guess that fair. most everything on a 2500 is $$$ except the suspension . john we got them beat with our solid axls man!
Old Dec 15, 2009 | 04:10 PM
OlDirtyJohn
I WISH!! 2500 2wd is IFS.
Got_Hemi44's Avatar
Got_Hemi44
Originally Posted by cheapbeater
for once i'm glad i have a 4x4... i could get gears front and rear, and a DTT for not much more than that...
Why are you glad you have a 4x4? It sucks having a 4x4 when changing gears because you have too do both the front and back.
Old Dec 15, 2009 | 04:42 PM
truckin151's Avatar
truckin151
Originally Posted by OlDirtyJohn
still waiting on the tq verter, just ordered it this weekend, and its the holiday season. so who knows when that is gonna get here. then ordering my 260 right after the holidays. i cant wait! then i gotta start saving up for headers, fastman tb, and E-fan.
Couple things...
With that TQ Converter I would strongly reccomend upgrading to the HD trans cooler if you do not have one (although you should since your truck is a 2500). If you dont, there are 2 different versions of the HD cooler, one is a wider aluminum cooler, if you are in the snow or colder climates that get down below freezing this is the one you want. If you live in the desert or warmer climate get the one off the 03'-04' 2500, this cooler basically looks like the size of your radiator, its huge, and will cool it down even further than the aluminum one will.
Second, after you get the converter installed your very next mod needs to be a trans temp gauge (if you do not have one already). The converter can/will cause extra heat. With roller bearings it probably wont be to much of a difference but just as a precaution I would get one just to keep an eye on things specially if you do not have the HD trans cooler and decide not to replace it.
Last, I know your truck, being a 2500, is quite a bit heavier than mine is, but after you get the gears and converter in, you may want to look into some mods to help a little with traction as well. Trust me, its no fun when you have all that power and tq at the wheels and you cant use it to your full advantage cause all you do is sit and spin.
Sorry if I made you mod list a little longer
Old Dec 15, 2009 | 05:41 PM
hemiguy0302's Avatar
hemiguy0302
I got my gears for my 2500 at 650$ CDN taxes in. That was both sets too. Installed it at dads shop with our mechanic telling me what to do and me pulling wrenches. What a learning experience that was.
Old Dec 15, 2009 | 05:50 PM
OlDirtyJohn
Originally Posted by truckin151
Couple things...
thanks for the info. i do already have the HD trans cooler (huge one). i am planning on eventually getting the temp gauge. i just still dont know which way i want to go yet. either single gauge pod a-pillar with the aeroforce interceptor (with wideband addon) or a 2 gauge a-piller with transtemp and wideband.
what are some mods to help with traction? that area is all new to me.
Old Dec 15, 2009 | 06:02 PM
HammerZ71's Avatar
HammerZ71
Yeah, the guy is not hosing you on the ring and pinion. $425-$450 is the going rate for either Chrysler or Yukon ring and pinions, plus about $100 for the install kit. Labor is on the higher end of the spectrum for a single axle, but still within range.
If he knows his chit, it's a fair deal...
Old Dec 15, 2009 | 06:12 PM
DodgeThunder's Avatar
DodgeThunder
For gauges have you looked into the isspro performax. Very easy to install and the isspros match the factory gauges very well. Im not a huge fan of stuff like the aeroforce where its just one gauge that does everything from the trucks computer. Id rather trust actual probes exactly where I want them where I put them.. And I think stuff like that looks tacky in a truck. Just my .02.. For the setup I use my handle to get into my truck everytime so I bought the srt pillar with the handle still and 1 gauge and I put a trans temp in it and I just bought the 4 gauge pod for above the mirror but Im not sure what to put into that yet, Most likely air pressure for OBA for horns and on the trail.. Rear diff temp.. Tcase Temp cause I use 4wd alot.. and ill figure the 4th out later.. you can get pods for above the mirror that hold 2, 3 or 4
http://www.dieselmanor.com/pillars_p...s_overhead.asp
http://www.isspro.com/performax_Whit...BlackBezel.php
