car audio experts, got a quick question
Old Dec 19, 2009 | 02:53 PM
05hemipwrd's Avatar
05hemipwrd
Default car audio experts, got a quick question
i know theres an audio section but i hear its slow so i thought id post in here...
i have 2 JL 10w3s 2ohms and im trying to bench test them to see if theyre still good. theyre dual voice coil so theres 2 connections on each side, i dont have a multimeter so i did the old 9v battery test. on one side it worked but on the other side nothing...i tried the next sub and the same thing. both worked on the same side though so i wasnt sure if it was normal. i wired one up in series and nothing but when i ran it parallel it worked but maybe thats because only one side works anyways....whats the deal yo?
Old Dec 19, 2009 | 03:01 PM
ramhunter9's Avatar
ramhunter9
we have a audio section ask this their.
Old Dec 19, 2009 | 03:04 PM
Frenchy's Avatar
Frenchy
Seriously RH?
You did read the first sentence, right?
Maybe check google? Or a local audio store?
Old Dec 19, 2009 | 03:05 PM
ramhunter9's Avatar
ramhunter9
no i didnt read it till you pointes it out frenchy lol i just ASSumed
Old Dec 19, 2009 | 03:51 PM
Frenchy's Avatar
Frenchy
sheesh... GOOD JOB!
jkjk
Old Dec 19, 2009 | 04:46 PM
dirtydog's Avatar
dirtydog
Moderate User
I don't know the battery test? I use a Digital multi-meter and test the voice coils individually. You can buy a cheap digi multi-meter for like $15 at Walmart or AdvanceAuto...etc
Old Dec 19, 2009 | 06:47 PM
05hemipwrd's Avatar
05hemipwrd
ill just wait for the week i guess....i have one at work but ive been off. the battery test...take a 9v battery and 2 wires, hook one up to each terminal on the speaker and touch the battery terminals, if the speaker moves that means its good
Old Dec 20, 2009 | 04:47 PM
lxman1's Avatar
lxman1
Site Moderator
It wouldn't be slow in the audio section if people would use it instead of the tech forums
Old Dec 20, 2009 | 05:35 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I have used AAs and 9v's to pop the coil. Not the best thing to do but it works. However, using a meter as Dogs suggested will allow you to compare the readings of one coil to the next.
Old Dec 20, 2009 | 05:46 PM
OklaHemi's Avatar
OklaHemi
maybe there should be a 3rd gen audio sticky. let dirtydog and weedahoe have at it for everyone who needs help here
