More MPG, 05 Ram 1500 5.7L
Old Dec 21, 2009 | 07:46 PM
RIDER's Avatar
RIDER
Default More MPG, 05 Ram 1500 5.7L
My 05 Ram 1500 with the 5.7L gets 14 mpg on the highway. What can I do to get more MPG's out of it?
Old Dec 21, 2009 | 08:01 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
Best mod I have done for the MPG's is the e-fan.
Old Dec 21, 2009 | 08:05 PM
Frenchy's Avatar
Frenchy
x2, e-fan brought my 4.7L 4wd from 18 to 19 on the highway to 20 to 21
Old Dec 21, 2009 | 08:07 PM
Off_Road_Teacher
The e-fan is also pretty inexpensive which makes it even better.
Old Dec 21, 2009 | 08:09 PM
RIDER's Avatar
RIDER
Not a bad idea. Was is wired to a relay that would be energized when the engine got to a certain temp? What fan was used?
Frenchy's Avatar
Frenchy
ya I did the taurus efan cost me all of 20 bucks for the fan, and 10 dollars for relays and wiring... and I don't think a 2mpg increase is bad for 30 bucks...
Old Dec 21, 2009 | 08:10 PM
Off_Road_Teacher
x2 on the Taurus fan. You can get them all day for between $20 and $30.
Old Dec 21, 2009 | 08:44 PM
chambers's Avatar
chambers
E-fan is the best way, just make sure you do it right b/c if you don't your engine may overheat. Also check your air filter and run some gumout regane or techron through the gas. I know my gas mileage usually drops when they switch over to winter blend fuel, good luck.
Old Dec 21, 2009 | 09:18 PM
davb673's Avatar
davb673
Yep, an Efan will definitely help. Be sure it pulls about 2700 cfm, or it won't cool the engine off fast enough. You can also make a belly panel for the entire bottom of the truck. Synthetic oil will get you a little bit. Tonneau covers help. I am told a Superchips on the 91 also helps, but I have not tried that yet. My truck is up to 24 mpg on the highway at 65mph...
You might also R2 (remove and replace) the Ypipe, and get a free flowing muffler in the back.
Old Dec 21, 2009 | 09:54 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
guys with 4.7s cant compare mpgs with guys with 5.7s, just isnt equal.
I love to drive my truck and Im always over 3k rpm but I know if I wanted to keep my mpg then I should keep my rpms below 2k.
