Pulled off rear diff. cover and found
Old Dec 29, 2009 | 12:29 AM
muddauber5.7's Avatar
muddauber5.7
Default Pulled off rear diff. cover and found
Nothing laying in the bottom of my diff. It's a 2003 with 70,000 miles. The first time I changed diff. fluid I just pumped the old fluid out, so after reading so many posts on here I figured I'll pull the cover off to get the clutch pack clip out of there. And I was extremely surprised to find it still intact. But before I did my truck, my buddy and I took the cover off of his 2002 with only 46,000 miles and found the clip in three pieces laying on the magnet, but has caused no damage to his gears so we buttoned his back up and he's leaving it that way.
Old Dec 29, 2009 | 12:33 AM
JoeHemi's Avatar
JoeHemi
my 04 has over 130,000 miles and I've never had a problem with the retainer clips. Hopefully it will stay that way for awhile since I don't have the money to swap gears/lsd yet.
Old Dec 29, 2009 | 01:10 AM
irelandshemi's Avatar
irelandshemi
my 03 with 130k hasnt had problems
Old Dec 29, 2009 | 02:15 AM
sad_drake's Avatar
sad_drake
my 07 has 56,000 ish and i had to have whole new spider gears (my own fault tho) i'll take that blame. other than that no problems at all
Old Dec 29, 2009 | 05:36 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
My 04 had broken clips at 60k and after the dealer didnt want to do anything about it other then flush it out and change the oil (original oil was pure silver) I replaced it with an Auburn LSD.
Old Dec 29, 2009 | 06:48 AM
MOPAR78's Avatar
MOPAR78
I probably should change the oil and look. I'm approaching 192,000 miles on my 05. So far it's never given any indication that something loose or broke.
Old Dec 29, 2009 | 08:22 AM
HammerZ71's Avatar
HammerZ71
Remember guys, this is a factory LSD issue, if you have an open differential you will have no clips to break...
Old Dec 29, 2009 | 11:07 AM
muddauber5.7
It sounds like this issue is hit or miss, it breaks on some trucks and does'nt on others which leads me to believe what I read on a thread once that said. If you drive it like you stole it all the time, racing, or hard throttle starts there's a good chance it's broken. Don't get me wrong I get on my truck once in a while but don't beat it. We pay too much for these trucks to beat them.
