help save a dodge before i burn mine
Old Jan 3, 2010 | 06:06 PM
Kamel87's Avatar
Kamel87
Angry help save a dodge before i burn mine
ok so im at the end let me say this first i love my truck but the problems are starting to tick me off. i have an 03 1500 4.7l ive had the normal problems diff radiator pcv valve ect. fixed them all now i have a problem and i dont know what to do. if you guys read my last post my valve body in my trans to a crap so i ordered a new on and got a new solenoid. today i took the trans pan off removed the valve body and replaced it with the new one with new solenoid and filters. filled it up with fluid and went on my merry way. well aparently at around 25 30 mph my truck thinks its ok to idle at 500 rpms. and at 70 mph when i take my foot off the gas the rpm drops fast to 1500 when i give it gas and i mean like pushing the pedal half way down it spikes to 2500 rpms and drops back to 1800 but the motor doesn't really speed up. then i push the pedal almost an inch away from the floor board and the rpm spikes to 3500 then with the pedal all the way down it spikes again to 4500 rpms. if there are any ideas please tell me what i should check or change because im almost on my last string. btw the check engine light is not on.
Old Jan 3, 2010 | 06:20 PM
lxman1's Avatar
lxman1
Site Moderator
Recheck the fluid level and reset the PCM.
Old Jan 3, 2010 | 07:20 PM
Horseapples's Avatar
Horseapples
i have a truck that needs an engine.....
Old Jan 3, 2010 | 07:42 PM
Kamel87's Avatar
Kamel87
I checked the fluids and they are good and I already reset the PCM. Horse do u need an engine meaning u wan to buy mine?? Because I'm looking to change out my motor and trans so if u are looking to sell or buy a motor we might be able to work something out pm me
Old Jan 3, 2010 | 07:46 PM
Horseapples
actualy, i am trying to unload this truck, it is a 2004 Bighorn that shelled the engine, it is black, fiberglass hood, 20'wheels and is debadged. I pulled the engine for the owner, he let it sit at my shop for 3 months, then went and bought a new Chevy. So he wants to unlosd this truck. He wants 4 grand.
Old Jan 3, 2010 | 08:45 PM
Kamel87's Avatar
Kamel87
the body on mine is almost perfect and i just rebuilt the diff and i have a lot of work in the interior so i want to use my shell i just need a motor because i have already spent 3000 on my truck fixing it in the last 3 months i figure that alone would have gotten me a motor
Old Jan 3, 2010 | 09:17 PM
TRXHemi's Avatar
TRXHemi
Did you figure it out yet? That sucks....do you have any mechanic friends that can maybe put a diagnostic on it? I guess if there is no engine light, then there is no code either....weird.
Old Jan 3, 2010 | 09:30 PM
Pyro's Avatar
Pyro
I Beat Tetris
Sounds like a trans solenoid problem to me...
Old Jan 3, 2010 | 11:16 PM
Kamel87's Avatar
Kamel87
the solenoid is brand new so idk tommorow im calling the trans shop i bought all the parts from and see what they say if they give me crap im going to try and push for a shift kit
Old Jan 4, 2010 | 02:14 AM
04-fourseven's Avatar
04-fourseven
Does it have tow mirrors that need unloading? Man my wife has fresh leather in her new Yukon, and im loving it. Dare I say, Im starting to like that damned GM product a lot. Anyways...
Your RPM problam sounds like a typical 4.7 with 3.55's searching for a power band. At 70, unless you hammer down, that 4.7 isnt going to do anything but waste fuel. The variance in your RPM (high to low) is just the torque converter locking up and releasing. My truck does the same thing.
SOlution: re-gear. I fixin to bite the bullet and order my gears. getting tired of the tranny searching all the time. Makes it a biotch to drive in town.
