How did you wire your electric cut out?
Old Jan 5, 2010 | 06:04 PM
02Steve1990's Avatar
02Steve1990
Default How did you wire your electric cut out?
As the title states. Received the cut out from oe football (thanks again) just a few minutes ago so I'm just wondering for those of you with cut outs, how did you wire them? I'm not sure whether to strip the wiring and go to the battery or to just plug it in to a 12v outlet in the truck? Please post pictures if you got 'em! Would like to see pics of both install methods please!?
Old Jan 5, 2010 | 06:10 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
What kind of cutout do you have? For my DMH I have it running off the 12v source that used to be the cigar lighter.
Old Jan 5, 2010 | 06:46 PM
02Steve1990
I have the raceland cut out. it has the 12v cigar lighter adapter but i can strip the wires if i want and go to the battery, just not sure what the best way is
Old Jan 5, 2010 | 07:11 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Mine is like Teach has his. It is wired to the inside of the cab and connects to both the (+) and (-) on the back of the cig lighter in the center console
Old Jan 5, 2010 | 07:16 PM
02Steve1990
weed you don't have an adapter to plug into the cig lighter? Did you strip the wires?
Old Jan 5, 2010 | 07:17 PM
02Steve1990
Going to the cig lighter seems easiest I just don't know how to get the wiring into the cab Pics of how you got the wiring into the cab?
Old Jan 5, 2010 | 07:40 PM
Off_Road_Teacher
There are plastic plugs in the firewall that you can drill through and run the wires through. That is where mine come into the cab.
Old Jan 5, 2010 | 07:43 PM
bighornram08's Avatar
bighornram08
I have mine plugged into the cig lighter. I put the wire through the firewall hole that's covered with rubber plug<--located under the steering wheel, there should be a factory wire already coming from outside to the insde of the cab. It's easier to start the wire from the inside of the cab and lead it outside.
Old Jan 5, 2010 | 07:46 PM
Matt99's Avatar
Matt99
most people just use the plug under the steering column...i have like 15 wires going through there
Old Jan 5, 2010 | 07:47 PM
bighornram08
