Changing Breaks
Old Jan 5, 2010 | 09:06 PM
wyseguy77's Avatar
wyseguy77
Default Changing Breaks
I think I'm gonna change my break pads tomorrow. I've changed break on my other cars in the past but never on a Dodge and want to make sure I have the needed tools before I dig in. I did a search and couldnt find anything. Any ideas? Thanks a bunch!
Old Jan 5, 2010 | 09:11 PM
Mega-Hemi's Avatar
Mega-Hemi
I would start by not breaking anything and concentrate on your Brakes..... just bustin ya.
Old Jan 5, 2010 | 09:13 PM
AF_HEMI's Avatar
AF_HEMI
for a BRAKE job it doesnt require anything different than your normal brake job tools... socket for the caliper bolts, large c-clamp for the pistons
Old Jan 5, 2010 | 09:24 PM
stuntpilot's Avatar
stuntpilot
Just my two cents worth.
Does anybody undo the beed nipples when they push the pistons back? I don't know about Rams as I have never done one. On some cars it can damage the ABS if you push the pistons back without the bleeders open.
Old Jan 5, 2010 | 09:32 PM
AF_HEMI's Avatar
AF_HEMI
no but make sure open the brake resevoir and keep an eye out for overflow
Old Jan 5, 2010 | 09:37 PM
JoeHemi's Avatar
JoeHemi
super easy job...you'll need to put some muscle into the 2 large bolts on each caliper mount holder dealio but other than that you won't have any problems. Also I used a couple of disc spreaders in place of the c-clamp and worked quite nicely.
Old Jan 5, 2010 | 09:39 PM
stuntpilot's Avatar
stuntpilot
Yes, I know that part, thats's why I haven't topped mine off in ages! I knew a pad change was immanent.
By disc spreaders you mean a big long screwdriver!
Old Jan 5, 2010 | 09:42 PM
AF_HEMI's Avatar
AF_HEMI
as far as i know doing this and opening the resevoir do the same thing... prevent unnecessary pressure when pushing in the pistons. i prefer the resevoir because it ensures no air gets in the lines
Old Jan 5, 2010 | 09:45 PM
Mega-Hemi's Avatar
Mega-Hemi
That and the last time I tried to open my bleeder screws 2 of them broke off..
Old Jan 5, 2010 | 10:31 PM
matthewbeard's Avatar
matthewbeard
haha thought i was going to break my damn arm off getting those two bolts free some rust and a lot of miles = stuck bolts
my haynes manual says just to open the resevoir up don't need the bleeds.
some safety wire or mechanics wire or whatever works geat to hold the caliper up out of the way if your changing rotors too - don't pull the brake lines off of the calipers or you'll have to bleed your system
