Gauge questions....
Old Jan 11, 2010 | 01:24 PM
Yeags777's Avatar
Yeags777
Default Gauge questions....
Hi Guys...
Couple of things I need answered so that I can complete my gauge install.
1.) Trans Temp Gauge - I need to find the thread size of the test port #3. The sensor that came with the glowshift gauge did not fit, so I will need an adapter. The sender is a 1/8th NPT temp sender.
2.) A/F ratio gauge - Can anybody pinpoint the Oxygen Sensor Signal wire? We tapped into a wire which we thought would work, but it didn't.
Almost complete and will take pics. Thanks for the help.
Old Jan 11, 2010 | 01:39 PM
shadow11's Avatar
shadow11
Here is Silvers DIY on the trans temp gauge https://dodgeforum.com/forum/3rd-gen...gauge-diy.html You need Autometer 3280 and Autometer 2259 adapters to make it fit in the test port.
Old Jan 11, 2010 | 02:10 PM
Yeags777's Avatar
Yeags777
Yes, iveread that several times, but I have the glowshift gauges. Will those adapters still work for my gauge?
Old Jan 11, 2010 | 05:39 PM
lxman1's Avatar
lxman1
Site Moderator
Don't you have to add a wide band O2 sensor to use the a/f gauge?
Old Jan 11, 2010 | 05:43 PM
hemiyellow's Avatar
hemiyellow
DC Insider
yeah, you need a wideband O2 to use a a/f gauge
Old Jan 11, 2010 | 06:45 PM
truckin151's Avatar
truckin151
yep you cant just tap into the O2 you need to add a wideband before the cat. Basically gotta drill a hole and weld in a new bung and wire it up.
Old Jan 11, 2010 | 07:47 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
Did you just buy the gauge or the whole wideband setup?
Old Jan 11, 2010 | 09:10 PM
Yeags777's Avatar
Yeags777
I thought wideband stuff was useful for when you do the tuning? I talked to a guy that owns a local truck performance/accessories shop and that was his advice.
Thanks for your guys input
Old Jan 11, 2010 | 09:17 PM
Off_Road_Teacher
A wideband is very useful when tuning your engine. But you need a complete wideband setup to monitor your a/f ratio, not just the gauge.
Old Jan 12, 2010 | 01:56 AM
Yeags777's Avatar
Yeags777
*sigh* back to the drawing board for the a/f ratio. So what do I need to complete this? Parts wise and install wise
