Lights in Bed (Under Rail)
Old Jan 23, 2010 | 02:23 PM
butch1581's Avatar
butch1581
Default Lights in Bed (Under Rail)
If anyone has pics/info on what lights to use or how they did it, that would be great. I want lights tucked up under the bed rails so I can see under my roll up tonneau cover at night. I am having touble finding WHITE lights. I am looking for like Neon or LED or whatever. Thanks for the help.
EDIT: I did find these:
http://cgi.ebay.com/ebaymotors/NEW-U...Q5fAccessories
Do you think they are crap?
Old Jan 23, 2010 | 02:33 PM
millertime363's Avatar
millertime363
Im doing mine right now actually. Ill post pictures when i finish them up. Im using for strips of these.
http://cgi.ebay.com/24-LED-Strip-Car...item27aae775ab
Old Jan 23, 2010 | 02:44 PM
butch1581's Avatar
butch1581
sweet man! I would like to see how bright those are when you are done. I am looking for useful light not for looks or anything. The ones you are using look like they are pretty bright. I would like to see pics for sure. How many 24" strips did you get?
Thanks
Old Jan 23, 2010 | 03:07 PM
Matt99's Avatar
Matt99
Thanks
24cm lol...it would take a ton to do along the entire side, but i bet a pair up front and a pair at the rear would do what you are wanting
Old Jan 23, 2010 | 03:18 PM
OlDirtyJohn's Avatar
OlDirtyJohn
recon lights makes exactly what you are looking for. might not be as cheap as what you can find on ebay, but the quality will be top notch.
Old Jan 23, 2010 | 03:26 PM
caliboy@heart's Avatar
caliboy@heart
Ive seen the ones from Recon...they do look good!
Old Jan 23, 2010 | 04:42 PM
06DodgeRam15004.7's Avatar
06DodgeRam15004.7
Maybe something like this.
http://www.gorecon.com/products.php?...Running+Lights
Old Jan 23, 2010 | 07:17 PM
butch1581's Avatar
butch1581
These would be long enough to wrap the 3 sides of the bed!
http://cgi.ebay.com/ebaymotors/Flexi...Q5fAccessories
Old Jan 24, 2010 | 10:21 AM
scubaboy's Avatar
scubaboy
hi
i used he same strip lights as millertme363, but i found 72cm lengths and put two either side under the rail with sticky cabe clamps
then i ran a live feed from the the permanent live at the ignition and put a pin switch in the bed so when th cover is lifted the lights come on
i will post some pics during the week
hope ths helps
Old Jan 24, 2010 | 01:20 PM
butch1581's Avatar
butch1581
Scuba:
How bright were the 72cm strips? Was it enough light? I found 120cm on ebay too, but by the time you buy 3 of them at $15 a piece, you could buy this kit with the remotes:
Does anybody know if neons still work good in cold weather?
Pics would be cool! thanks
