3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Hey guys descided to change the plugs in my 04 4.7. i went with the autolite 3923 since that seens to be the one most use. i didnt think they would be too worn out since i only have 67000 mile but i wasnt sure when they were changed last. well they look pretty spent. heres a pic of what i found. i was going to clean the throttle body too but i couldnt get the connectors on the 2 sensors to unplug. any suggestions?
I changed out the plugs on my 03 4.7L last month. Only 65k miles but the plugs looked just like yours. Surprised me too. Not sure what to say about the 2 sensors. Mine didn't give me any problems unplugging.
how did u get the back passenger side one out? i have an 05 4.7 and i have a cluster of wires sitting on top of it so i can pull the coil pak off or get myself back there,lol
The TB plugs should come right off. They each have a tab on them that you have to move and then pull it off. Try rocking the plugs back and forth. Don't pull on the wires or they may rip out.
i didnt have any wires on top of mine. there was a bundle running next to the coil pack. i did unbolt the oil dip stick so i could get back there easier. do the wires have enough slack to move them over so you could get the coil off. i did find they dont give you much extra wire to pull those coils out.
